box making gadget
Re: box making gadget
If you use the normal dovetail gadget you can make the sides without dovetails on the bottom. Little bit more work though.
lawrence
Model of CNC Machine: CNC Shark HD
Post by lawrence »
dah79 wrote:Using the box gadget, is there a way to not have the dovetails made on the bottom edge of all the parts? I do not have selected to make a top or bottom. I would like to just have a straight bottom as I will put a dado in all the sides for the bottom.
This looks like a pretty cool gadget. Maybe I am asking too much... Thanks
I tested using the node edit mode to delete the dovetails on the bottom- when I recalculated, the imported pin carvings created an error, but that didn't seem to have an effect on the rest of the recalculation and it (appears) to have worked!
not a perfect workaround, but it seems to be a workaround for this very cool gadget. I'm quite excited to give it an actual try on my machine :)
Hope this helps-
Lawrence
sharkcutup
Post by sharkcutup »
its there now, just downloaded it
http://gadgets.vectric.com/V9/box_creator.html
I have downloaded that particular file and it does not install. Noted that the file extension is .vgadget and not .exe so this is probably why it would not install.
Sharkcutup
V-Carve Pro 12.005
Vgadget is the correct extension for V9 products that support gadgets. They can be installed by double clicking the file or by using the Install option on the gadgets menu.
spottsd
Model of CNC Machine: Legacy Arty
Post by spottsd »
I am having trouble trying to install the boxmaker gadget
Does it work with Aspire 8.5?
How do I get it installed?
Cheers
Dave
It's not available on the pre-version 9 gadget site and the v9 format gadgets won't install in earlier versions.
The dovetail gadget is available though and you can make boxes with that - http://gadgets.vectric.com/V8/dovetail.html
gvguitars
Model of CNC Machine: custom built
Post by gvguitars »
Will this gadget ever work again?
I got this error message (picture attached) when I try to install it.
(my current Aspire 9.519)
Which gadget are you referring to? This thread has discussed at least three at various times.
Generally if you get an error extracting the vgadget file it shows that the download didn't complete properly. Re-downloading it should solve the issue.
AdamJ
Model of CNC Machine: None
Post by AdamJ »
Hi All
Prior to version 9 I don't think there was a release version of this gadget. It just lived on my computer and was shared around the office. Since then we have release a version:
Version 9:
http://www.vectric.eu/gadgets/V9/Vectri ... et.vgadget
Version 10:
http://storage.vectric.com/gadgets/V10/ ... ll.vgadget
Both should install correctly, as Adrian points out the vgadget file is mostly a renamed zip file so if there is an error extracting it has probably been corrupted in some way.
Cheers,
Adam
Onetrack
Model of CNC Machine: Workbee
Post by Onetrack »
The box making gadget remembers all previous settings, but resets the allowance to zero! Please can it be updated to remember all previous settings, including allowance? Thank you.
The more I learn the more I forget.
sharkcutup
By Onetrack
All it would take is a couple of added lines in the .LUA script to set the allowance to a default just like the other entries.
Sharkcutup
V-Carve Pro 12.005
mrleonwhite
Model of CNC Machine: Legacy Maverick 3x5
Post by mrleonwhite »
Hi Guy's,
I tried installing the Box creator gadget in Aspire 10.514 and I get this error
mrleonwhite wrote:
Fri May 14, 2021 2:52 am
Hi Guy's,
You've installed a version meant for V9 not V10.
This is the correct link - https://gadgets.vectric.com/V10/box_creator.html
mrramsey1969
Model of CNC Machine: ShopSabre Pro404
Post by mrramsey1969 »
I seem to be experiencing an issue when using this gadget with V11. I set up my job then run the gadget but instead of fitting the objects within the boundaries of the sheet they draw off of the sheet even though there is ample space within the sheet. Am I missing something??
As you're using the finger joints you can move the vectors to wherever you want them and recalculate the toolpaths. Using the nest tools (if available in your vectric software) is also an option.
The gadget doesn't try to fit the parts on the material. It just creates them.
