4th Axis Incomplete Finish Cut
- Model of CNC Machine: Axiom AR6 Pro+
Re: 4th Axis Incomplete Finish Cut
SteveNelson46 -
I am importing & using the larger OBJ file and not an STL file.
When either the STL or the OBJ file is used, and a raster angle of 0-degrees is used, this problem manifests.
When either the STL or the OBJ file is used, and a raster angle of 45-degrees is used, this problem does not manifest.
I wonder....
Since the problem shows up when the Y & Z axes increment and the next command is to rotate 1 full turn
Either
- from A0.000 to A360.000 - OR
- from A360.000 to A0.000
Could the controller be interpreting that as a NULL motion?
Do I need a controller firmware update?
Code snippet -
N64100G1A0.000
N64110G1Y88.639Z22.494
N64120G1A360.000
N64130G1Y88.798Z22.465
N64140G1A0.000
N64150G1Y88.957Z22.434
N64160G1A360.000
N64170G1Y89.116Z22.396
N64180G1A0.000
I wonder....
Either
Code snippet -
N64100G1A0.000
N64120G1A360.000
N64140G1A0.000
N64160G1A360.000
N64180G1A0.000
I see you have an axiom machine. That usually means you either have a DSP controller or UCCNC
Take a look at a setting called "Rollover on 360" in UCCNC. "Rot 360 Rollover" in Mach3. No idea what it is called on the DSP.
You gcode calls A360, A0 repeatedly after the crown section. See snippet.
N63080G1A360.000
N63090G1Y80.530Z17.037
N63100G1A0.000
N63110G1Y80.689Z17.228
N63120G1A360.000
N63130G1Y80.848Z17.420
N63140G1A0.000
N63150G1Y81.007Z17.611
N63160G1A360.000
I would suggest that the controller is just taking the shortcut between 0 and 360
N63080G1A360.000
N63100G1A0.000
N63120G1A360.000
N63140G1A0.000
N63160G1A360.000
Pretty sure it's a DSP controller
It's a RichAuto B18
Image from the Internet - Mine has all english writing on the buttons
I have heard of no rollover equivalent for this controller
It's a RichAuto B18
It should be there somewhere. Look at the manual or ask the manufacturer.
It would surprise me if there is no way to control that behaviour.
One way around this would be to change your finishing strategy.
Have the cutter travel along the length of the piece with the rotary turning a small amount each pass.
That is the way I do most rotary jobs.
This does work.Greolt wrote: ↑Tue Mar 16, 2021 9:21 pmIt would surprise me if there is no way to control that behaviour.
With the same RASTER finishing pattern and changing the default raster angle from ZERO to any non-zero value will successfully finish the piece.
It would still surprise me if the controller has no way to control that rotary axis behavior.
If that is so then the controller is quite deficient for rotary axis use. IMO
Not sure what PP you are using but on my machine the "regular" G94 post processor (feedrate=distance/min) does not work well when cutting mostly rotation moves because the machine interpretes that as feedrate=degrees/min. If I am lucky it works but often the axis stalls because the commanded angular speed or acceleration exceeds the machine's capability.
Using a "G93" post processor (feedrate=1/(move time)) is supposed to fix that but many machine controllers can not handle the G93 (or not properly).
For that reason I try to lay out the tool paths mostly along the rotary axis and then the G94 method works perfectly.
Puzzle, Finger Joint, Maze and Guilloche freeware at https://fabrikisto.com/tailmaker-software/
Yes -
The machine was going from 0.00 degrees to 360.00 degrees via the shortest path... which is no movement at all along the rotary axis.
Talking to Chad at Axiom Precision got me through this.
There is a setting buried DEEP in the controller settings, and it is not mentioned in the 4th axis documentation.
Change that setting from “NEAR” to “NORMAL” resolves this issue.
There are a few “GOTCHA’s” to changing this setting, so I advise making the call to Axiom Precision and have them walk you through the process if you are having this problem.
Tailmaker -
The post-processor is supplied by Axiom Precision.
They have 3 PPs for their ARx machines:
- 1 for 3-axis projects
- 1 for rotary (4-axis) projects
- 1 for LASER projects
Tailmaker -
- TReischl
Re: 4th Axis Incomplete Finish Cut - FOUND A BUG
Many posts later HBruns wrote: "There is a setting buried DEEP in the controller settings, and it is not mentioned in the 4th axis documentation.
Change that setting from “NEAR” to “NORMAL” resolves this issue."
This is an example of why I am hesitant to call something a "bug".
- JoeBlow
- Model of CNC Machine: AxiomAR6Pro
and even sometimes the answer is there all along
Also mentioned on the Axiom forum in a couple places.
Patrick
The hurrier I go, the behinder I get
