Mantel
- Model of CNC Machine: Workbee & Self built 4X4 (heavy duty)
Mantel
Thanks to Michael Tyler, made these out of pine to start as per Michaels design and was so impressed with the result I decided to make them as a two sided project out of oak. I then made the L frames creating the profiles using A two rail sweep, a good learning curve.
I then set about the mantel itself using a length of 4" x 1" oak using a similar two rail sweep I'm sure there must be a simpler way, I then constructed the shelf using oak veneered board for the top and bottom and wrapped the profiled piece around the front and sides. I am really pleased with the result, just need to finish the rest of the fire place now.
Paul
Paul
- mtylerfl
Re: Mantel
Thank you, Paul! Your corbels and shelf in Oak look fabulous! Very clean carves!
Re: Mantel
Every time that you look at that, it will make you feel good.
Excellent work.
Excellent work.
Re: Mantel
Plus 1, great job!Your corbels and shelf in Oak look fabulous! Very clean carves!
Gary
Re: Mantel
The corbels really work well in the design.
- SteveNelson46
- scotttarnor
- Model of CNC Machine: Axiom AR8 Pro V5+Jetch Laser+Rotary
Re: Mantel
The learning curve was obviously worth it! +3
Re: Mantel
Many thanks for all the positive comments, just need to get to grips with my own complete design.
Paul
Paul
- Model of CNC Machine: BZT PFE1000-PX
Re: Mantel
wow
- Model of CNC Machine: Homemade
Re: Mantel
+1
