Cursor/scrollwheel behaviour haywire
Hoosterw
Model of CNC Machine: Sainsmart Prover 4030
Post by Hoosterw »
After toolpath previewing the cursor in the 3D view map is going haywire or at least the 3D object skirts and swipes around when pointing and clicking and its hard to get the behavior as before. I have to go out of the model and re open and the behavior is normal.
Any way to keep this from happening?
SteveNelson46
Re: Cursor/scrollwheel behaviour haywire
Post by SteveNelson46 »
If you have a wireless mouse be sure the receiving unit is within 3 to 5 feet of the mouse. Also, if you have an optical mouse try cleaning the lens. Worked for me. Maybe not for you.
Hoosterw
Post by Hoosterw »
Thanks, but its a Wacom tablet mouse. So unlikely it will be the problem.
As said it happens when I have had a preview of the toolpath. when I want to click and drag the model in 3D view it changes its orientation upon the click.
Hoosterw
Post by Hoosterw »
Just thought to give it a bump.
Check in the Options under the Edit menu to see if you have "Use graphics tablet" set to Yes. If so try setting it to No and restarting.
Post by Rcnewcomb »
Also check for driver updates.
Hoosterw
Post by Hoosterw »
The drivers were up to date, thanks.
But apparently the setting use graphical tablet was set to YES, setting to NO did it for now.
Thanks Adrian.
regards Hans
