Truncated Cone
SomeCNCGuy
Model of CNC Machine: FGP Solutions
Truncated Cone
Post by SomeCNCGuy »
Just wondering if anybody has created a Gadget that will calculate and create a toolpath that will cut the side panel for a Truncated Cone?
Re: Truncated Cone
Post by adze_cnc »
Would the "Chamfer Gadget" help? Or, if you are running v10.x of VCarve or Aspire the chamfer toolpath?
You could also do this with a moulding toolpath.
FixitMike
Re: Truncated Cone
Post by FixitMike »
And, another method: The fluting toolpath:
conical taper fluting.crv
Material cut away to show cut
(201 KiB) Downloaded 203 times
Re: Truncated Cone
Post by highpockets »
You could use the Moulding Toolpath.
Re: Truncated Cone
Post by TReischl »
I am thinking the OP wants the flat layout of a truncated cone. . . . like sheet metal.
FixitMike
Re: Truncated Cone
Post by FixitMike »
Here's a calculator for the layout of the side: https://www.templatemaker.nl/en/cone/
The .svg option will make a file with the proper vectors you can import.
Re: Truncated Cone
Thanks for the link Mike....
SomeCNCGuy
Re: Truncated Cone
TReischl wrote:
Wed Dec 09, 2020 2:25 am
Yes that is exactly what I am enquiring about. In my work I frequently have to create Truncated Cones. I am aware of the math involved in creating a panel (ie. Sheet Metal) but I find it somewhat laborious to calculate the math and do the layout in Aspire 10.5. There are many Calculators & tools for creating Truncated Cones available on the internet so it seems to me that a gadget to create a Toolpath in VCarve and Aspire would be a welcome addition.
Re: Truncated Cone
Sounds like a project for Jim "jimandi5000" if you can talk him into it :D
SomeCNCGuy
Re: Truncated Cone
Thnx for the suggestion HighPockets. I will suggest that to him.
