Update Program Error
- Model of CNC Machine: HomeBuilt
I received the following error when trying to use the update program. Any ideas as to what might be causing this? Windows is up to date. Fresh reboot was done prior to retry. No other applications were opened.
- fretsman68
Re: Update Program Error
What kind of update are you trying to do? If it's an update from 10 to 10.5 then you need to do a complete new instal of 10.5 you can't use the blue update icon in the top right of the screen
- fretsman68
Martin, what version are you running at the moment? Were you able to upgrade with no issue clicking the link inside the software?
Dave
Dave
- Model of CNC Machine: CWI Professor 2.2
I tried the update from inside the program and it failed. Different error but still failed. I went to the update site at Vectric and with some minor anomalies got it to update.
https://www.vectric.com/support/program-updates
- fretsman68
I ended up doing that as well with no issues.ken whiklo wrote: ↑Tue Nov 03, 2020 7:38 pmI tried the update from inside the program and it failed. Different error but still failed. I went to the update site at Vectric and with some minor anomalies got it to update.
Dave
Dave
I run Aspire so don't know if that is the difference, I updated via the blue link in top right corner from 10.507 to 10.509fretsman68 wrote: ↑Tue Nov 03, 2020 6:54 pmMartin, what version are you running at the moment? Were you able to upgrade with no issue clicking the link inside the software?
- fretsman68
I went to the https://www.vectric.com/support/program-updates area, downloaded and ran the appropriate patch. It worked!
- mtylerfl
When using/clicking the update message within the software, a lot of folks forget to shut down their Aspire or VCarve program immediately after the Update window appears on-screen. This causes the update to fail because their Aspire or VCarve software is still running.
- fretsman68
Hi, Michael, there was definitely something different about this update that did not load right. I've done this before.mtylerfl wrote: ↑Tue Nov 03, 2020 10:02 pmWhen using/clicking the update message within the software, a lot of folks forget to shut down their Aspire or VCarve program immediately after the Update window appears on-screen. This causes the update to fail because their Aspire or VCarve software is still running.
Dave
Dave
- mtylerfl
Hi Dave,
Thank you for letting me (us) know!
- SteveNelson46
- mikemel
- Model of CNC Machine: X-Carve 1000mm
The update to 10.509 seemed to install correctly for me however I get a recurring error with files that previously carved just fine.
"No toolpath generated for current parameters. Check tool can fit into selected vectors at machining depth"
