Organizing STL Files and Adding to ClipArt
Post by Rcnewcomb »
Over the years I've collected a lot of STL files. If you have Aspire you can convert your STL files to 3dClip files and then add them to your ClipArt section within Aspire.
The process I use is as follows:
Create a new project that is 6x6x1 with Very High Resolution.
Go to File/Import/Import Component / 3D Model
Select the STL file and resize it to fit withing the project dimensions
After you have completed the import go to the Modeling Tab and right click on the component and select Export as 3D Clip Art
Save the 3dClip file in a folder under where the Clip Art is stored. You can add your own folders to aid in organization.
Later, when you open Aspire and look through your clipart you will see the new file(s) in the preview. Use them like any other clipart.
10 fingers in, 10 fingers out
another good day in the shop
Hermie
Model of CNC Machine: custom
Re: Organizing STL Files and Adding to ClipArt
Post by Hermie »
Thanks Randall, brilliant, I have a few files that would work on. Maybe it will force me to get organized too.
Clockman
Model of CNC Machine: Home made/Linear rails/1605 Screw-drive
Post by Clockman »
Thank's for posting that, very interesting
ZipperHead55
Model of CNC Machine: Axiom AR4Pro+ and AR8Pro+
Post by ZipperHead55 »
I'm just seeing this post for the first time, and I have been doing this for a while now, but the only difference is I tended to go much bigger (24" x 24" x 1.5"+), in case I needed the crests larger than 6" (I was thinking I would lose resolution if I started smaller (6", as per OP's suggestion) and then go larger for my actual carvings.
I never experimented with what the "sweet spot" is: large enough to be detailed, but not so large/detailed as to be a resource hog, and I'm wondering if anybody else has (ie am I wasting time, processing power, etc by making it so large, or am I "future proofing" by having that clipart at a higher resolution in case I need it larger. Nowadays, storage space isn't such a concern: I'd rather have a highly detailed model at 250MB (or larger) than wishing I had made it larger (to save on storage space) and ending up with a "meh" quality carving later down the road.
As an aside: make sure you don't have models/components hidden when you do the exporting to clipart: the clipart will have those hidden components in it's model tree (thereby making it larger, more cumbersome than neccesary). This may have been changed over newer updates, but I distinctly remember this being an issue when I was an eager beaver, converting ALL of my 3D models to clip-art, so I didn't have to go through the Import STL process every time I brought in models I wanted to add to a project.
Allan
Holzarbeiter
Model of CNC Machine: Camaster Stinger SR24
Post by Holzarbeiter »
Thanks for the excellent tip,Randall!
Is there anything magical about the 6x6x1 size you use?
Joe
I have a chip on my shoulder....several more in my hair and lots more all over my shop floor.
Post by Rcnewcomb »
It corresponds to the size of most of my projects. <wink>
Holzarbeiter
Rcnewcomb wrote:
Mon Dec 21, 2020 6:39 am
Got it...thanks! Im already putting this clever idea to work.
Thanks again & Merry Christmas!
Joe
