Creating a circle with a gadget
GrainDesign
Model of CNC Machine: Ascent pro
Post by GrainDesign »
Hi there
I'm just learning how to create gadgets and was wondering what the easiest way of creating a circle within a gadget is.
I have tried to use the CreateCircle() global method but cant seem to get it to work it just keeps returning a nil value. (Maybe I'm doing something wrong)
Would it be easier to us the contour:ArcTo() method and us either 2 or 4 lines arced to make the circle.
any help would be appreciated.
thanks
Re: Creating a circle with a gadget
This is a bit of code based on an example SDK script that draws a circle using CreateCircle.
Code: Select all
-- VECTRIC LUA SCRIPT
require "strict"
function AddGroupToJob(job, group, layer_name)
   local cad_object = CreateCadGroup(group);
   local layer = job.LayerManager:GetLayerWithName(layer_name)
   layer:AddObject(cad_object, true)
   return cad_object
end
function main()
    local job = VectricJob()
    if not job.Exists then
       DisplayMessageBox("No job loaded")
       return false;
    end
   local group = ContourGroup(true)
   group:AddTail(CreateCircle(0,0,20,0.0,0.0))
   AddGroupToJob(job, group, "Circle Example")
   job:Refresh2DView()
   return true
end
Chelmite
Model of CNC Machine: Legacy Maverick 4x8, BOSS laser
Post by Chelmite »
AddGroupToJob is not in the 10.5 SDK. How do I add the group to the job in 10.5?
Chelmite wrote:
Fri Aug 14, 2020 9:18 am
AddGroupToJob is a user defined function as shown in the code in the previous post. It's not part of the SDK. Just copy the code and put it into your code.
Chelmite
Post by Chelmite »
Thanks! I figured it out, but am unable to delete my question.
jimandi5000
Post by jimandi5000 »
GrainDesign wrote:
Tue Dec 05, 2017 8:49 am
Hi there
thanks
Hi GrandDesign,
Have you looked at a SKD Wiki I built?
https://jimandi.com/SDKWiki/index.php?title=Main_Page
I have code posted to help show how to draw with Gadgets. have a look at this one: https://jimandi.com/SDKWiki/index.php?t ... w_a_Circle
Let me know if you need help.
Jim
