Requesting Gadgets
- Vectric Staff
- Model of CNC Machine: 6040 Desktop CNC
Requesting Gadgets
This forum has been created so users can submit suggestions for Gadgets they would like to see in the software.
Please be aware this is a place for suggestions only and is no guarantee that Vectric or any other user will create the resulting Gadget.
If you would like to learn more about creating Gadgets please visit
http://gadgets.vectric.com/developerinfo.html
- Ms Wolffie
Re: Requesting Gadgets
Can I please have a gadget that stops me from making dumb mistakes like deleting a file when it shouldn't be?
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Model of CNC Machine: Joes Evo 3x2
That would fit in with a feature request I made some time ago to have Aspire do what I want it to do rather than what I tell it to do. C'mon Vectric, make it happen! How hard could it be?Ms Wolffie wrote:Can I please have a gadget that stops me from making dumb mistakes like deleting a file when it shouldn't be?
- krugshouse
- Model of CNC Machine: Blackfoot v4.2, VCP 8, Mach 3
Will the halftoner gadget be available in Vcarve Pro?
Have a safe machining day
That gadget relies on creating a 3D model from a bitmap. Something that VCarve can't do.krugshouse wrote:Will the halftoner gadget be available in Vcarve Pro?
For VCarve you can use Jason Dories HalfToner program - http://jasondorie.com/page_cnc.html
Export as a DXF file, import that into VCarve, select all the vectors and create a VCarve toolpath. I use it all the time and it works great.
- Ms Wolffie
Thank you Vectric for providing the "undelete" step.Ms Wolffie wrote:Can I please have a gadget that stops me from making dumb mistakes like deleting a file when it shouldn't be?
PHEW, now I MAYBE can save what's left of my hair
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- ryadia
- Model of CNC Machine: 6040 USB CNC 4 axis Router/Engraver
I'd really like to see 'radius all corners' updated for use with Version 9 of Vcarve Pro.
A Gadget to round the edges of a board after the corners were radiused would be very useful for me. Not sure about others.
Ryadia
Ryadia
Will there ever be a gadget for a tapping cycle?
Have you seen the Threads gadget? #8 on this page ... http://paulrowntree.weebly.com/gadgets.htmlpaulw616 wrote:Will there ever be a gadget for a tapping cycle?
Cheers!
Paul Rowntree
- sharkcutup
Reference "Box Creator Gadget"
It would be nice if the "Box Creator Gadget" could include options for a "Bottom" & "Sides" (Bottom Edge) to be created with No-Tabs or Dovetails. Maybe in the place of Tabs or Dovetails include a Rabbet on the sides and ends bottom edge. Essentially thereby creating a box with only Tabs or Dovetails in the "four corners" with or without a Tabbed/Dovetail Lid.
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- sharkcutup
Something Similar to this.Reference "Box Creator Gadget"
Sharkcutup
I have created an .htm file for it but not really sure how to modify the LUA file to accommodate it.
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- Model of CNC Machine: shapeoko xl
through dovetails
Hi, is there anybody who can make a through dovetail gadget, for end-grain milling?? I mean I have made with trial and error real dovetails in the front of my waste-board,I needed 12 drawers to match an existing cabinet with 12 missing drawers, For that it was worth the trial and error method. And I also tried blind dovetails, in one go, pin-board and tail-board. But life would be much easier with a gadget Kind regards Hans
Re: through dovetails
There is a dovetail gadget here - viewtopic.php?f=51&t=34728hans pijpers wrote: ↑Wed Aug 12, 2020 5:53 pmHi, is there anybody who can make a through dovetail gadget, for end-grain milling?? I mean I have made with trial and error real dovetails in the front of my waste-board,I needed 12 drawers to match an existing cabinet with 12 missing drawers, For that it was worth the trial and error method. And I also tried blind dovetails, in one go, pin-board and tail-board. But life would be much easier with a gadget Kind regards Hans
Thanks, but those are not through dovetails, those are with dog bone holes, A through dovetail is seamless !
That gadget is a through one. The boards have to be held vertically at the end of the machine as that is the only way to do a through dovetail without requiring specialist bits.
The "official" (Vectric gadget site) gadget has dogbones as that is cut flat on the table.
