Scaling Off
Cardan
Model of CNC Machine: Bob's CNC E4
Scaling Off
Post by Cardan »
Very new to the CNC world.
Just tried my first cut with Cut2D Desktop 10.503. I was cutting a 1-inch wide strip with a slight curve. The final pieces actually came out to about slightly less than 7/8".
I am using a 1/4 inch bit on the machine and setting up for a 1/4 inch when programming the tool and toolpath via Cut2D.
For the Machine Vectors, I am setting it as Outside / Right with a Conventional direction, and 0 offset.
I design in Sketchup then export/import as a PDF and then rescale to the dimensions of the board size. The rescaling does not seem to impact the final scale in Cut2D as the piece does measure back to the 1-inch width I am going for.
Any ideas as to what the issue could be? Thanks in advance.
gkas
Re: Scaling Off
Post by gkas »
Post your Cut2D file. That way we can look at it, otherwise it's a lot of guesses.
Cardan
Re: Scaling Off
Post by Cardan »
Thank you for the response. I was hoping it was going to be something easy :)
Below is a link to the file. For some reason this forum does not accept files with a ".GCODE" extension.
I am using UGS Platform if that makes a difference. Thank you again.
https://www.dropbox.com/sh/4g7361halw38 ... Hbkia?dl=0
FixitMike
Re: Scaling Off
Post by FixitMike »
We need the file with a .crv extension. It is the one you get when you do a file save in Cut2D. It can be attached here.
Cardan
Re: Scaling Off
Post by Cardan »
Sorry about that. Still on the learning curve of all this.
I can't find the original crv from the one I sent earlier but here is another one with the same issue (I cut from multiple files as I was experimenting with layout and not paying attention to final dimensions).
Test2piecev2onlypieceinmodel.crv
(87 KiB) Downloaded 90 times
gkas
Re: Scaling Off
Post by gkas »
This CRV example was cut with a TRIAL VERSION of the software. It cannot be read by anyone else. How did you cut with a trial version?
Cardan
Re: Scaling Off
Post by Cardan »
The last file sent (trial version) was the only CRV file I saved, which was before I bought the license.
Apparently I have not been saving any of the crv files after I exported to G-code.
I will run another test and report back. Thank you for your time. I do apologize. (I'm still on the bottom of the learning curve).
gkas
Re: Scaling Off
Post by gkas »
No problem. Just post it when you recreate it.....
Cardan
Re: Scaling Off
Post by Cardan »
Ok, So I did a test file (crv attached) with basic shapes designed in Sketchup and then imported in Cut2D. I am still about a 1/16th off on all the cuts.
Is this a Sketchup thing or am I doing something incorrectly?
DimensionTest.crv
(53.5 KiB) Downloaded 74 times
gkas
Re: Scaling Off
Post by gkas »
The crv file is correct. Either the bit size used was incorrect, an incorrect pp was used, or your CNC needs calibration. I would test the calibration first.
Cardan
Re: Scaling Off
Post by Cardan »
what is "pp"? (sorry, still learning the lingo)
jfederer
Model of CNC Machine: CanCam D23M
Re: Scaling Off
Post by jfederer »
PP=Post Processor... the template that generates the GCode that runs the CNC. These are often specific to a machine, although the GRBL is fairly generic.
Joe Federer
www.fabrikisto.com incl. Tailmaker software
www.federer.ca
Cardan
Re: Scaling Off
Post by Cardan »
Thank you!
rsetina
Model of CNC Machine: Shark HD 2.0
Re: Scaling Off
Post by rsetina »
I looked at the file too and it looks okay to me too.
Rick
Shark HD 2.0
