Easy Dovetail Maker 5.0
- jimandi5000
Hello Everyone,
First thing. Thank you BillK for the feedback on Version 4.0. It was great guidance.
I hope all of you are health and safe. I have been busy. Here is version 5.0 of the Dovetail Gadget. I have updated the Help Files and posted a new video on YouTube (see link below)
https://youtu.be/KB_HWWHLsGc (3 minutes)
Items Fixed:
1. Supports VCarve Pro Version 9 and 10
2. Fixed the dovetail layout
Please let me know if you have question or errors.
I am off to the next big thing...
Items Fixed:
Jim
Jim
- jimandi5000
Re: Easy Dovetail Maker 5.0
Here is the Gadget.
- EasyTools20200515.zip
- All Easy Gadgets
- (2.45 MiB) Downloaded 410 times
Jim
Jim
- Model of CNC Machine: CNC Shark Pro Plus
Thanks Jim. Can’t wait to try this out. Video looks good, those joint will plane off nicely.
BillK
- jimandi5000
- SteveNelson46
Jim,
Nice job with the gadget and the video. I'll have to make a vertical jig for my machine to try it out.
Jim,
Your mission, should you choose to accept it...
BillK
- jimandi5000
Hi Bill,
No!!! I do not accept.
I will tell you I spent the day in the shop with my middle son. We are building him a bed and we used the Dovetail Gadget for the drawers that go under the bed. After using the gadget, I will be adding some more functions to the tool.
Thinking of adding:
1. Adding both right and left hand toolpaths. For the front board, I just show one end and I had to go and flip the Pins to mill the other end. I think I can do it in the code faster.
2. Backer Board thickness... as you can see in the YouTube video, I was getting a lot of tearout and chipping on the parts. Today, we started off with some failures due to chip out. We had to place backer boards on the front and back of the part to stop chip out. I have to trick the software to add to the thickness but is caused the bit was plowing into the backer board. Not good.
3. Adding Fit adjustment to the Front Board Pins. I have Fit adjustment on the Side Tails but it would be nice to also have it on the Front Pins. Today, I had to play with the Front Pin location in VCarve to loosen up the joint to get a better fit (no sledge hammer needed).
I will post my updates as I fix the code.
Jim
Jim
- jimandi5000
Thanks Steve! I have to say my vertical jig needs some work. Today, I added a quick hold down clamp and it made a big difference on mounting the material to the mill it was like having a 3rd hand.SteveNelson46 wrote: ↑Sat May 16, 2020 4:51 pmJim,
Again, thanks.
Jim
Jim
- jimandi5000
Hello All,
I found a small bug in the code. Here is Easy Dovetail Maker Version 5.01
I am working on Version 5.2
- EasyToots20200517.zip
- All current Easy Gadgets
- (2.45 MiB) Downloaded 247 times
Jim
Jim
- jimandi5000
Hello all,
My hope for you and your family that all are healthy and safe.
Here is Version 5.2
I have made extensive changes and updates to the easy dovetail maker gadget. With the current version at 5.2 you will find a number of enhancements.
Version 5.2 additions:
1. Backer board capability for the prevention of chip out when cutting side material with dovetail cutting it
2. Left and right hand orientation for cutting the front board pins
3. Front pin fit adjustment capabilities
4. Additional code clean up and error trapping
5. Updated documentation (Wiki and pdf)
Suggestions and Feedback is always welcome.
Never hesitate to let me know if you're having issues.
Here is Version 5.2
- EasyTools20200518.zip
- Most current version of all easy gadgets
- (2.5 MiB) Downloaded 259 times
Jim
Jim
Hi Jim - I'm excited to try your gadget. I have VCarve Pro 9.5 and when I download both the 20200515 and 20200518 versions I get the error "Failed to extract the vgadget archive".
I tried downloading the file from both Edge and Chome, and extracted the zip file to my desktop. If I double click on your EasyTools.vgadget file or if I go to the Gadgets -> Install new Gadget menu I get the same behavior above. If I rename the .vgadget file to a .zip file, I can open it and see the contents no problem, so I'm pretty confident it isn't a file corruption issue.
Googling seems to suggest that this error relates to the gadget not being compatible with the version of VCarve. Your first post said compatible with 9 and 10. I'm running 9.5.
Thanks for any ideas you may have,
TJ
TJ
- jimandi5000
Hi TJCornish,TJCornish wrote: ↑Mon May 25, 2020 9:33 pmHi Jim - I'm excited to try your gadget. I have VCarve Pro 9.5 and when I download both the 20200515 and 20200518 versions I get the error "Failed to extract the vgadget archive".
TJ
I am perplexed on this issue. I no longer have version 9.5 due to buying a new PC. Therefore, I have no way to test the Gadget install function.
Does anyone out there have knowledge on why the zip file with .vgadget is not working for Version 9 or 9.5?
Jim
Jim
- jimandi5000
Hi TJCornish,jimandi5000 wrote: ↑Mon May 25, 2020 11:16 pmHi TJCornish,TJCornish wrote: ↑Mon May 25, 2020 9:33 pmHi Jim - I'm excited to try your gadget. I have VCarve Pro 9.5 and when I download both the 20200515 and 20200518 versions I get the error "Failed to extract the vgadget archive".
TJ
Would like to test something. Can you install this one? (just a test)
- EasyDovetailMaker.zip
- (2.3 MiB) Downloaded 215 times
Jim
Jim
- Model of CNC Machine: HomeBuilt
Hi Jim,
FYI.
I noticed DovetailTool.ini gets overwritten when updating or reinstalling. I added a test tool and when I updated and it was no longer in the tool list.
Andy
FYI.
Andy
- jimandi5000
Hi Andy,
I am sorry about the data loss. I do not think I can prevent the ini file from being overwritten when updating or reinstalling. But as I think about it, I could add the version number to the folder name. That would address the version updates but would not address any reinstall. I could move the bit data to the registry, but the number of bit may need to be limited due to the data structure. How many bits do you think you need?
Jim
Jim
