Acrylic tabs
Aussie
Model of CNC Machine: Robotics Model 8
Acrylic tabs
Post by Aussie »
Hi All,
I am cutting small acrylic pieces and need to use tabs, to cut tabs I normally use a flush cutting saw but these pieces are too small for this saw.
I think the pieces are too small to use the CA glue method as well.
Can you suggest a method to cut the tabs?
Ron
Crafers Crafts
Re: Acrylic tabs
Post by TReischl »
Hmmm, maybe dig through some hobby type stuff, like model railroad guys use.
I have a very small trim saw that I picked up somewhere, the blade is only about 8 mm wide.
There might be something for an eXacto knife too. . . .
Just tossing some ideas out there.
Re: Acrylic tabs
For the types of plastic I usually cut I just us a sharp 1/4" chisel to get through the tabs. Some varieties of acrylic would shatter with that though. Dremel type tool with a cut off wheel maybe?
GEdward
Model of CNC Machine: 24 X 36 3 Axis
Re: Acrylic tabs
Post by GEdward »
Maybe a hot knife attachment for a wood burning pencil or soldering iron. Grind it down to a shape that you can use?
Re: Acrylic tabs
Post by mtylerfl »
Xxray
Re: Acrylic tabs
Post by Xxray »
scroll saw
Re: Acrylic tabs
Post by Rcnewcomb »
If you are making a number of these it might be worth making a custom vacuum fixture with gasketing. It eliminates the need for tabs.
Aussie
Re: Acrylic tabs
Post by Aussie »
Thanks for all the great ideas.
Ron
Crafers Crafts
