Blanket Chest
- Mike-S
Blanket Chest
Rather than hijack a V-carve post on dovetails, I'll post here. This is a hickory chest. Large top compartment and drawer below. You probably recognize the eagle on the drawer front. I also V-carved around the outline of the drawer pulls. Dovetail is more of a bear ear. Each hickory plank runs around end/front/end, including the piece for the drawer. Corner joints were done with Aspire.
- Model of CNC Machine: CNC Shark Pro Plus
Re: Blanket Chest
Really Beautiful job! Nice work. That will be passed down for sure.
BillK
- Model of CNC Machine: ShopBot PRT ALPHA 48"x96"
Re: Blanket Chest
That is beautiful and great craftsmanship!!! Would you be willing to give a tutorial on the Side Joints and the Bear Paw joints? If at all possible and possiblity that you would share a portion of each of the joints as crv or crv3d files?
Joe
Joe
- highpockets
Re: Blanket Chest
WOW Mike!!!
Absolutely beautiful craftsmanship. The dovetails really make it...
Thanks for sharing...
- gkas
Re: Blanket Chest
That looks fantastic.... and I have my hands full making sure my boxes are square.
- scottp55
Re: Blanket Chest
That's a beautifully Crafted chest Mike!!
Especially like how you carried the board around 3 sides!
Well Done!!
Well Done!!
- Model of CNC Machine: Camaster Stinger SR24
Re: Blanket Chest
Thanks for the detailed pics of the chest, Mike. That is really some outstanding work!
What a beautiful keepsake. Be proud....very proud indeed.
Joe
I have a chip on my shoulder....several more in my hair and lots more all over my shop floor.
- Mike-S
Re: Blanket Chest
Thanks, guys.
Here's the info on the "dovetails."
The front is cut vertically thru a hole in the bed.
The two sides are cut conventionally--flat on the bed. Those vectors are enlarged by 0.01" to allow for fitting and glue. Depth of both cuts was 3/4" to match the board thickness.
.DXF's are for a 0.25" EM and are about 8" long, so will cut some air for shallower drawer sides or you can clip the vectors.
Do a practice cut in cheap pine before you commit to the good wood.
- beardoveEND.dxf
- (31.62 KiB) Downloaded 106 times
- beardoveFlat.dxf
- (152 KiB) Downloaded 115 times
Re: Blanket Chest
You're going to need a new name for the drawer front joint. Looks more like a jigsaw joint than a dovetail joint to me.
Re: Blanket Chest
Thanks for posting your method, I will give it a good try next week.
Joe
Joe
- Mike-S
Re: Blanket Chest
- Mark's Wood Chips
- Model of CNC Machine: ShopSabre 23 with Rotary
Re: Blanket Chest
Getting the board plumb and indexed properly for cutting must be challenging, I don't see any stops or plumb adjustments. One clamp doesn't seem adequate to prevent slippage during milling. Can you share some insight into how you manage your setup? Dovetails and box joints are finicky little things.Mike-S wrote:Thanks, guys.
The workmanship on the chest is outstanding!
Mark
Last edited by Mark's Wood Chips on Fri Feb 14, 2020 12:38 am, edited 1 time in total.
Re: Blanket Chest
Thanks for sharing the dxf file, Mike! Cant wait try try this out....but first I need a hole in my cnc table.
Joe
- Mike-S
Re: Blanket Chest
Mark, good eye, full disclosure--that picture was a setup. The vertical backer board has sandpaper glued to it (to prevent shifting) and line-up lines scribed into it (for plumb) and I use multiple clamps. Origin for X,Y is still lower left corner of the end grain.Getting the board plumb and indexed properly for cutting must be challenging, I don't see any stops or plumb adjustments. One clamp doesn't seem adequate to prevent slippage during milling. Can you share some insight into how you manage your setup? Dovetails and box joints are finicky little things.
