dovetails using CNC
dovetails using CNC
Has anyone found a way to cut dovetails using their CNC with V Carve Pro 10
- sharkcutup
Re: dovetails using CNC
With 9.5 V-Carve Pro I have using the Dovetail Creator Gadget
And there is another Dovetail Gadget where you can cut the end of boards off the end of the CNC table too! (Have not tried this one besides I do not have the off the table fixturing for it)
Have not had the luxury yet to upgrade to V10 yet but I do have the trial version just to keep up with things/progress!
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
http://gadgets.vectric.com/V10/dovetail.htmldbreckon wrote:Has anyone found a way to cut dovetails using their CNC with V Carve Pro 10
- sharkcutup
Thank You Adrian
I forgot that "Big" detail in post a link! ARRRRGH!
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- Model of CNC Machine: Camaster Stinger SR24
Wow, Mike, those are beautiful joints! You made them using Aspire/Vcarve?
I also like the finger joint cabinet in the pic.....would love to see the whole thing!
Joe
I have a chip on my shoulder....several more in my hair and lots more all over my shop floor.
- scotttarnor
- Mike-S
Thanks, yes they were done in Aspire.
- Model of CNC Machine: CNC Shark Pro Plus
https://forum.vectric.com/viewtopic.php ... be#p133032
In the third comment, you’ll see a pdf of how I did mine. Works really well.
BillK
Conventional dovetail joints aren't outrageously hard to make toolpaths for if you have some basic drafting skills and a way to clamp each half of the joint vertically. You need to know the specifics of the bit you'll be using (blade angle and widths at bottom and the depth of the joint.). I typically cut dovetails for my students once or thrice each semester. All types except for the very narrow hand cut versions that no router bit can produce.
4D
4D
Where can I find the gadget for creating dovetails off the end of the table?And there is another Dovetail Gadget where you can cut the end of boards off the end of the CNC table too! (Have not tried this one besides I do not have the off the table fixturing for it)
Jeff
- sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- Mike-S
Sure. IIRC I left 1/100" space for fitting and glue.
- BearDoveTails2.dxf
- (672.89 KiB) Downloaded 211 times
