I'm trying to create a Butterfly wing with Aspire 10.019.
I created the line vectors by hand tracing a bitmap. I select the outline, then used create shape to create the basic outline. I then select all the inside closed vectors (only). I'm not sure if I want this detail raised or lowered, so I just hit APPLY. I get this weird figure 8 shape created. I checked for duplicate and open vectors, and did 'select all' to see if I left old vectors. What have I got wrong?
Google Drive link to crv3d https://drive.google.com/file/d/1OJANZs ... sp=sharing
Weird Shape Create
- mezalick
Re: Weird Shape Create
Gerry,
You do have an open vector ( see attached picture)
I'm not sure if this caused your problem, but if it's closed I get the end result that you're looking for.
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- gkas
Yup... Thanks. I forgot that Vector Validator doesn't check for open vectors. When it's late at night, just put it away and check it in the morning.
