Easy Cabinet Maker
Re: Easy Cabinet Maker
It seems to be a very generational thing. With the other software I've worked on older people wanted documentation and younger people wanted videos with some being extremely vocal if their chosen format wasn't available. Personally I prefer the written word and screenshots as I find videos are nearly always too slow paced so my attention wanders and then I start skipping forward which sort of defeats the purpose.
- jimandi5000
Great Feedback... Looks like I will doing both written help and a how to video.
Jim
Jim
Jim,
I really appreciate how much you are contributing. You are making this a great community of craftsmen (and women) where we help each other with creative solutions.
Thanks!
Thanks!
- jimandi5000
So happy to help. My goal is to show everyone it's not hard to build their own gadgets. I had a hard time getting started so, I am trying to set this up to kickstart their learning.Rcnewcomb wrote:Jim,
Thanks!
Jim
Jim
- jimandi5000
Hello All,
First, Thanks Bill for the feedback on the error.
Here is the new version 7.0 of the Easy Cabinet Maker Gadget.
Next Steps:
1. Update the Help Wiki with the new help format
Next Steps:
- EasyCabinetMaker.zip
- Rename to EasyCabinetMaker.vgadget
- (36.44 KiB) Downloaded 228 times
Jim
Jim
- jimandi5000
Hello All,
Here is Versions 7.1
I was working on the cabinet gadget for someone and I added a simple Color selection to the layer dialog.
Let me know if you have issues.
- (37.81 KiB) Downloaded 227 times
Jim
Jim
- Model of CNC Machine: FLA Saturn 4x4 / 7W & 60W lasers
I get a 'Failed to install' error when trying to install the latest version 7.1. I have changed the extension to .vgadget
Dave
- jimandi5000
Thanks for letting me know... Can you see if this addressed the issue?
- (37.75 KiB) Downloaded 255 times
Jim
Jim
- jimandi5000
Hi Dave,
Tell me about your system and have you tried copying the gadget file directly to your Gadget folder and see if that works?
you will need to open the zip file and find the EasyCabinetMaker7.2.lua file and copy it to the EasyCabinet folder.
i.e. "C:\Users\Public\Documents\Vectric Files\Gadgets\...\EasyTools\EasyCabinetMaker\"
and restart your vectric software.
Jim
Jim
I found out that if I copy the folder with the ,lua file into my Gadget Folder, that it did work. If I changed the file type to .vgadget and tried to 'Install' the gadget it did not work. I am running Aspire 10.502 and Windows 10. Hope this helps.jimandi5000 wrote: ↑Wed Jul 08, 2020 4:43 pmHi Dave,
Dave
- jimandi5000
Thanks Dave,
I am not sure what the issue is, sometimes it works and sometimes it doesn't. Glad we got it working.
Jim
Jim
I’d like to give this a try!
Is there a more condensed how to for this gadget- I’ve tried every which way to get this to work-
I am running vcarve pro 9.5- and downloaded the final version of the gadget for cabinet maker and tools and hinge files- I’ve Renamed and added file as specified Then added into the gadget folder And just keep getting the error - saying project not loaded or a Nil error- When attempting to open the gadget in Vcarve. Any input would be appreciated! Thanks
- jimandi5000
Hello Njboost,NJBOOST wrote: ↑Fri Oct 09, 2020 2:38 pmI’d like to give this a try!
For Version 9.5 and below try this version of the gadget.
- EasyCabinetMakerVer09-7.2.zip
- rename to EasyCabinetMakerVer09-7.2.vgadget
- (37.92 KiB) Downloaded 274 times
Jim
Jim
- Model of CNC Machine: Shapeoko 3D XXL
In this Gadget can box /finger joints be created for cutting them vertically
Jeff
Jeff
