Box Creator Mods
This forum has been created for users to submit suggestions for Gadgets
leversole
Model of CNC Machine: OX Type
Box Creator Mods
Post by leversole »
Would like a small change in the box creator, may be simple...I have looked through the code and cannot find the right spot...
What I would like is to suppress the small "tails" where the router bit sets clearance for the sharp corners of the dovetails...I use a very small bit and through testing, I do not need these...I have been going through and node editing the tool paths to get rid of these, very time consuming!
I am hoping that these are done with a fucntion call that I can supress, or a series of lines in a function I can rem out...If someone can point me the section of code that creates these I would be most appreciative
Leslie
leversole
Re: Box Creator Mods
Post by leversole »
Maybe not the correct way...but it worked...
jimandi5000
Post by jimandi5000 »
Would like it turned off or as an optional setting or based on a bit size?
Jim
leversole
Post by leversole »
Probably optional is better than based on bit size...
jimandi5000
leversole wrote:Probably optional is better than based on bit size...
I will have a look and see if I can add that option. :)
Jim
