Blooming Lotus
Mobius
Blooming Lotus
Post by Mobius »
I love doing epoxy inlays. Sure, it may be a fad right now, but they can still look pretty sweet.
Connor Bredin
www.distinctive-concepts.ca
Re: Blooming Lotus
Post by highpockets »
Beautiful work! I too like using epoxy in my projects.
Thanks for sharing.....
jimandi5000
Re: Blooming Lotus
Post by jimandi5000 »
Very nice.
Jim
Beltramidave
Model of CNC Machine: FLA Saturn 4x4 / 7W & 60W lasers
Re: Blooming Lotus
Post by Beltramidave »
Very neat! Where are you getting your pigment?
Dave
Re: Blooming Lotus
Post by scottp55 »
Simple AND Elegant Connor!!
You've got the "Touch" :)
Creation in Wood
Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
Re: Blooming Lotus
Post by Creation in Wood »
Very nice project
Thank You
mfirlott
Re: Blooming Lotus
Post by mfirlott »
That just pops out. Very eye-catching.
(Mitch)
CAMaster Stinger I
Vectric Aspire
Epilog 45watt Helix Laser
RebeccaJ
Model of CNC Machine: Various
Re: Blooming Lotus
Post by RebeccaJ »
I think this looks lovely! Thank you for sharing this! Would you care to share the process? I would love to try something like this :D
Thank you,
Beki
Beki
Mobius
Re: Blooming Lotus
Post by Mobius »
RebeccaJ wrote:I think this looks lovely! Thank you for sharing this! Would you care to share the process? I would love to try something like this :D
Thank you,
Beki
I can do that for sure, it isn't difficult by any means.
For this project I first V-carved a piece of maple, hollowing out some pockets for the lotus leaves. I then sprayed some fast drying acrylic clear coat inside the pockets, to create a barrier so the coloured epoxy doesn't bleed into the wood.
Next I picked some relatively fast curing epoxy (~10 min pot time), and mixed it with some coloured metallic pigments from BlackDiamondPigments.com. Don't overdo it with the pigment, you only need a tiny amount to colour a large amount of epoxy.
I poured the epoxy into the flower cavities, and then waited until the epoxy was starting to harden but still viscous enough to self level. At this point you can move the epoxy around with a stir stick to disturb the pigment and create different effects. This takes some practice and timing. Too early and the pigment may settle to the bottom, too late and the epoxy won't self level and you will have to start over.
Next run a torch or heat gun over the still-curing epoxy to break the surface tension and help any bubbles rise to the surface and pop.
Once the epoxy is fully cured, I surfaced the piece with my CNC to remove any excess. I also pre-sanded the epoxy area to 320 grit.
To add a little depth, I also pocketed the area around the lotus down 1/16th, before V-carving the lettering at the bottom. The lettering was then painted with some metallic black paint.
Final sanding, a little coconut oil, and done. Total time (not including waiting for the epoxy to cure) was a little less than an hour to make two these.
I have a couple in-progress CNC clips on my Instagram as well @distinctiveconceptsltd
Connor Bredin
RebeccaJ
Re: Blooming Lotus
Post by RebeccaJ »
Thank you for this! This is really useful, I will definitely be trying this in the new year :)
Yes!
I spotted you this morning! I'm starting to notice more forum users over on Instagram :D
Thank you again for all of this useful information :)
Beki
