Easy Euro Door Hinges Maker
- jimandi5000
Hi all,
I hope you are doing well today.
Just completed a new gadget the "Euro style door hinge pocket maker. To use the tool select the outer edge (closed polyline) of the door and then start the Gadget the dialog will let you put hinges on any side of the door and you can put 2, 3, or 4 hinges on the door. Enter your hinge dimensions on the dialog and they will be saved and reloaded the next time you run the gadget. I looked at the Blum site https://www.blum.com/us/en/products/hin ... /overview/ to get the hole sizes and spacing. Have a look and I need some feedback.
- EasyCabinetTools.zip
- (1.38 MiB) Downloaded 292 times
- Hinge2.jpg (3.11 KiB) Viewed 18539 times
Jim
Jim
- Model of CNC Machine: Camaster Stinger SR24
Re: Easy Euro Door Hinges Maker
Holy cow, Jim, this looks really cool! You have been busy cranking out some very useful stuff to the forum members.
Im going to download this and see what it does. I only have a small 2 x4’ machine but for hanging cabinet doors this looks very promising. Thank you so much for your time and talent and willingness to share!
Joe
I have a chip on my shoulder....several more in my hair and lots more all over my shop floor.
- jimandi5000
You are so welcome... I physical cannot get in the shop right now so I am trying to learn how to write Vcarve gadgets. If you have a Gadget need... let me know.Holzarbeiter wrote:Holy cow, Jim, this looks really cool! You have been busy cranking out some very useful stuff to the forum members.
Jim
Jim
jimandi5000 wrote:You are so welcome... I physical cannot get in the shop right now so I am trying to learn how to write Vcarve gadgets. If you have a Gadget need... let me know.Holzarbeiter wrote:Holy cow, Jim, this looks really cool! You have been busy cranking out some very useful stuff to the forum members.
Well, off the top of my head I can't think of any....but I will consider your offer a challenge!
Joe
- jimandi5000
My neighbor was putting cabinets in his shop and asked if he could run some doors on my mill. So I broke out the door/Hinge gadget and he gave me some feedback on how to improve it.
So, here is the 4.0 upgrade...
I've already started upgrading all the user interfaces, Wiki Help and user videos to all of the Easy gadgets and will post them as I complete them.
A quick how to video.
https://youtu.be/OgiFH2GrLtY
- EasyEuroHingeMakerVer4.0.zip
- Rename to EasyEuroHingeMaker.vgadget
- (51.58 KiB) Downloaded 204 times
Jim
Jim
- Model of CNC Machine: HomeBuilt
Re: Easy Euro Door Hinges Maker - Error
Hi Jim,
Different error. When I pressed the Help button after opening the gadget I received this error. Is it Windows config problem or something missing in the gadget causing this? Or?
Andy
Andy
- jimandi5000
- jimandi5000
What happens when you press the "Yes" button?
Jim
Jim
- jimandi5000
jimandi5000 wrote: ↑Mon Jun 15, 2020 9:05 pmQuestions:
1. What happens when you press the "Yes" button?
2. Is it only the About button
Jim
Jim
jimandi5000 wrote: ↑Mon Jun 15, 2020 9:09 pmWhen I press the yes or the no nothing visibly happens. All other button or dialog options function as expected. When I press ok the results are generated.jimandi5000 wrote: ↑Mon Jun 15, 2020 9:05 pmQuestions:
So, it appears only the "Help" button. BTW, the help on any of screens does the same thing.
- jimandi5000
AcBCDN wrote: ↑Tue Jun 16, 2020 12:07 amGREAT!!! I know how to address this issue.jimandi5000 wrote: ↑Mon Jun 15, 2020 9:09 pmWhen I press the yes or the no nothing visibly happens. All other button or dialog options function as expected. When I press ok the results are generated.jimandi5000 wrote: ↑Mon Jun 15, 2020 9:05 pm
Questions:
Jim
Jim
- jimandi5000
Here is the 4.01 hot fix...
Version 4.01 will fix the following:
1. Removed and replaced Java script to open new web page to show the help with html code to avoid the Reg issue
2. Fixed the Hinge offset location if overlap is added.
- EasyHingeMaker.zip
- (51.55 KiB) Downloaded 189 times
Jim
Jim
Sorry to report that the exact same error occurred with the "Help" button.jimandi5000 wrote: ↑Tue Jun 16, 2020 2:09 amHere is the 4.01 hot fix...
- jimandi5000
Ok, let me have a look tonight.AcBCDN wrote: ↑Tue Jun 16, 2020 9:25 pmSorry to report that the exact same error occurred with the "Help" button.jimandi5000 wrote: ↑Tue Jun 16, 2020 2:09 amHere is the 4.01 hot fix...
Jim
Jim
- jimandi5000
Okay... Version 4.02
Removed the HTML code and moved it to CSS.
Please let me know if it works.
- Rename to EasyHingeMaker.vgadget
- (51.66 KiB) Downloaded 224 times
Jim
Jim
