3D Finish Raster Not Cleaning Up Vector Boundary
JGolden
Model of CNC Machine: Shopbot
Post by JGolden »
I have a 3D Finish toolpath (Raster). Is there a way to make it follow the vector boundary on the last pass?
GFP-1021.001-0.75SBD - Copy.crv
(496.5 KiB) Downloaded 51 times
Re: 3D Finish Raster Not Cleaning Up Vector Boundary
Post by TReischl »
Why don't you use the vectors you used to create the model?
It looks like you had vectors to cut the shape out. So what you do is select the profile toolpath, tell it to project onto the 3D model and set a ridiculously shallow depth of cut, like .0001.
Your file did not contain those vectors that I could find.
BTW, it is a bad idea to model a smaller part in a huge sheet, you lose resolution on the model itself.
Post by highpockets »
What Ted said.
Try reducing the Stepover on the tool. Also the blue line isn't the outside edge of the bit, it's the center line of the bit.
JGolden
Post by JGolden »
TReischl wrote:Why don't you use the vectors you used to create the model?
Projected profile toolpath worked! Thanks.
highpockets wrote:What Ted said.
I will look at the stepover, thanks.
