Round over edges
Aussie
Model of CNC Machine: Robotics Model 8
Round over edges
Post by Aussie »
Hi All,
Please advise how I achieve a round over or softening of the edges for the hearts, this is for a box insert tray.
Ron
Ron
Crafers Crafts
Pete Cyr
Model of CNC Machine: Camaster Stinger II
Re: Round over edges
Post by Pete Cyr »
I would add 10% ramp and then smooth a bit
4DThinker
Post by 4DThinker »
Using a point cutting roundover bit like these: https://www.amazon.com/Amana-Carbide-Cu ... B00EBZG4JQ you can get the effect show in my render from Aspire.
You would need to describe the bit as a form tool, and then profile cut using it ON the heart outlines.
4D
Aussie
Post by Aussie »
Thank you 4D
Funny thing... I have this bit as it came with my Amana Kit they describe it as a "Breadboard" bit, never knew what it was used for..... guess you can tell I am new at all this :D
Ron
Crafers Crafts
4DThinker
Post by 4DThinker »
Not to worry, Aussie. We were all new at one time.
4D
Aussie
Post by Aussie »
I would appreciate if you could show me the toolpath you used....
thanks
Ron
Crafers Crafts
4DThinker
Post by 4DThinker »
I made this in Aspire 9.5, but saved it as a Vcarve file. Enjoy.
4D
Hearts 4D.crv
(818 KiB) Downloaded 322 times
MillAlien
Model of CNC Machine: Laguna Swift 4x4
Post by MillAlien »
This is awesome - I love the plaque but as a newbie also love being able to see how the design was tool-pathed.
Everyday in every way this gets a little less mysterious.
Oh, and a little more expensive. Tool paths require tools. Collection growing. Now considering buying Amana stock.
Aussie
Post by Aussie »
4DThinker wrote:I made this in Aspire 9.5, but saved it as a Vcarve file. Enjoy.
4D
Hi 4D thank you for the tool path file.... can I push the friendship and ask for the 56125 tool file as I normally use the Amana website to down load the tool file for Vectric, unfortunately this tool is not listed.
Thanks and regards,
Ron
Ron
Crafers Crafts
4DThinker
Post by 4DThinker »
I'm not sure what you are asking, Aussie. If you need to know how to add the tool to the tool database then draw a side view of the right half of the bit. Have that vector selected as you open the tool database. Select NEW..., then pick Form Tool from the list. The whole bit profile should appear. You can name it what you want, and specify cutting parameters, feeds, and speeds.
I'd rather you try doing this on your own, as once you've done it you can do it for all odd bits you acquire without needing help.
4D
Post by mtylerfl »
Hi Ron,
It looks like Amana has both a DXF and a PDF of the 56125 profile shape available for download here:
https://www.amanatool.com/56125-solid-c ... r-bit.html
Scroll down to “DXF Files” and click on it. You will divide and use half of the vector shape when creating the Bit in the Tool Database
Aussie
Post by Aussie »
mtylerfl wrote:Hi Ron,
Hi Michael,
Thank you for the link unfortunately I was unable to create a guest account...just returns an error and you need an account to download the DXF file.
Have used my pc and MAC to try...both times an error..... will try again later.
Ron
Crafers Crafts
Aussie
Post by Aussie »
Thank you all.... have made the form tool and the preview looks great, shall cut over the weekend.
Ron
Crafers Crafts
