hard time with rotary
mservis
Model of CNC Machine: Laguna Swift 4x4
Post by mservis »
I am really having a hard time with the rotary. what I want to do is table legs with a clip art of a walleye (which I have). It keeps putting the clip art in the middle, which of course is not seen. Also I get
the error model thickness exceed material thickness. Can anyone help me with this? I have adjusted everything I know. the tutorials don't discuss model thickness problems.
I have in 4 years only completed one project with the clip art in the correct. I am pretty desperate at this point, If someone is in MN I will pay for them to come help me with this. If not I will sell my equipment.
Thank you
Mary
mservis
Re: hard time with rotary
Post by mservis »
vectric, can you help with problem solving on this? can I send you the files
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Post by sawmiller »
which software do you have? vcarve pro or aspire ?
in reguads to model thickness,
if you select your model in aspire on the modeling tab 4th row down, there is a icon like a cresent wrench.
click on it and you can change your model properties. like thickness there is also a scale z thickness of model on the same line
as far as having model on the surface when you go to the toolpathing side under material setup, you can adjust your model location in the block of wood.( you want it to the top of course)
In the heart of Tn
mservis
Post by mservis »
I am using aspire. I will try your suggestions. Thank you.
Post by Rcnewcomb »
The forum is for user-to-user support. It is sometimes monitored by Vectric staff, but if you need Vectric support then it is best to contact Vectric by e-mailing SUPPORT@VECTRIC.COM
10 fingers in, 10 fingers out
another good day in the shop
mservis
Post by mservis »
OK, i figured it out. I had to add a layer and put the clip art in that layer on the top. Thank you.
