- PTBDRAW.DXF
- (1.11 MiB) Downloaded 209 times
DXF files.
- Model of CNC Machine: Oozenest Ox 500 x 750/Openbuilds Minimil
DXF files.
Hi all, I am trying to open a DXF file of a model boat which has been set out as a series of A4 size sections. When I try and load it into Cut2D it is tiny and seems to slow the program right down and won't let me rescale any of the sections. Can anyone point me in the right direction?
- SteveNelson46
Re: DXF files.
Open a new project that is 105" by 55". Then import. Works in Aspire. Don't know about Cut2D
Re: DXF files.
If it's tiny, your job setup is in inches and the dxf file is in millimeters. Go into job setup and change it to mm then import the file. After you imported the file, you can go back into Job setup and change back to inches and it will automatically resize everything.
Gary
Gary
Re: DXF files.
Many thanks. How will I cut it into suitable sizes for my machine without losing the correct scale?
Re: DXF files.
Watch this training video on Toolpath TilingHow will I cut it into suitable sizes for my machine without losing the correct scale?
Re: DXF files.
Change the job setup to mm BEFORE you import the file. Should be no reason to lose the proper scale. IF you want to work in inches, AFTER you import it, go back into job setup and change back to inches. It will automatically scale to the correct size.Many thanks. How will I cut it into suitable sizes for my machine without losing the correct scale?
Gary
- TReischl
Re: DXF files.
Since you are probably not building a full size PT boat with machine guns and torpedoes I figure the dimensions are in inches.
That drawing is going to be a lot of work.
First thing I would do is make a copy and then remove all the lettering, that will reduce the file size a lot and make it easier to deal with. Then I would export each group (they are actually arranged on "sheets" already) as a separate file. After that it will get a lot easier. I notice that most of the vectors are not closed so you will need to use the join tool.
There is also some overlapping geometry that you will have to find and get rid of.
Neat model!
Neat model!
- Model of CNC Machine: Wabeco F1410 LF-C HS; Sorotec AL1110
Re: DXF files.
Hi all,
I have a related question to the dxf import to Aspire V10: most of my dxf-files uses a specific unit for the included vectors (i.e. inch, cm or mm). This unit is defined inside the header of the dxf-file using a parameter called "$INSUNITS". But Aspire does not care about this parameter and always uses the unit which is defined in the job setup.
Is there a way to tell Aspire to use the unit which is defined inside the dxf-file? Maybe as a feature for an upcomming update?
regards
Klaus
regards
Klaus
Re: DXF files.
No way that I know of but if you open the file rather than importing it it's obvious from the job setup that is displayed whether it should be metric or imperial and you can click the units you want at that stage.
- adze_cnc
Re: DXF files.
In this case the DXF is in inches and the Cut2D file is in mm. Dilemma but different units of measure.garylmast wrote:If it's tiny, your job setup is in inches and the dxf file is in millimeters.
You can use "Set Selected Objects Size" and use 2540% as the scaling factor to convert the inches to mm.vip-klaus wrote:Is there a way to tell Aspire to use the unit which is defined inside the dxf-file? Maybe as a feature for an upcomming update?
Steven
Re: DXF files.
Thanks to all. I know that the size can be scaled. But my hope was, that there is a way to force Aspire to use the units included inside the dxf file.
No big problem at all.
Klaus
Klaus
- adze_cnc
Re: DXF files.
I find the much software ignores any encoded units of measure. When I pulled that DXF file into Rhinoceros to look at it Rhino wanted me to confirm an import of mm (I created a mm model space). It nicely scaled the file when I said inches but still it didn't offer inches as default...
Steven
Steven
Re: DXF files.
Same here. I opened the dxf file using CATIA V5 (!) and it doesn't recognize the included units. Finally I tried Alibre Design and: wow, it saw the units correctely. Then I changed the units inside the Alibre settings and stored the dxf-file with the corrected units. Fantastic!
I will ask the Vectric staff to include this behavior as a new feature for an upcomming release af Aspire.
Klaus
Klaus
Re: DXF files.
Technically, INSUNITS does not specify the units of the drawing. It specifies the units of blocks or other items imported into the drawing. (when importing into AutoCAD)most of my dxf-files uses a specific unit for the included vectors (i.e. inch, cm or mm). This unit is defined inside the header of the dxf-file using a parameter called "$INSUNITS".
Re: DXF files.
Yes maybe. But the result is the same. If I import a dxf file including a circle with diameter 10 cm, Aspire creates a circle with diameter 10 mm or 10 inch - depending of the setup I choose for the current part.
Unfortunately sometimes I have to use an specific design tool to create shapes of guitars and this tool only works with inches or cm. And as a german, I don't work with inches.
