Hello,
I have cut a texture area tile into a piece of wood that is .774” thick. The thickness of the texture area tile (model thickness) is .375” with a gap above of 0 and a gap below of.399”. After cutting the texture area tile I wanted to do an inlay pocket in this area. I tried doing a cutting depth of .125” and it did not cut deep enough. I tried a different depth and it went too deep. I am wanting it to cut .125” deep into the texture area tile.
Thanks for your help!
Inlay Pocket in Texture Area Tile
- TReischl
Re: Inlay Pocket in Texture Area Tile
If you are saying the texture is .375 deep and you want to remove all of it where the inlay pocket goes then you need to set your start depth to .375 and cut depth to .125.
Otherwise you could start at 0 and tell it to cut .5 deep and watch it cut air for a while.
