Cutting a flute or grove in the sidee of project
disneyfan1974
Model of CNC Machine: Black Diamond Shark
Post by disneyfan1974 »
I am using Aspire 9.5 with an upgraded Black Diamond Shark CNC. Is there anyway to cut a flute or grove in the side of a project with a side cutting bit? I do it now with my table router but it is a pain to set up and get an accurate cut. Any advice would be appreciated.
Re: Cutting a flute or grove in the sidee of project
You can certainly do it but you have to use leads in the toolpath or create the vectors to lead in and out. You won't be able to preview it as Vectric software doesn't support undercuts.
disneyfan1974
Thanks, I will give it a try. I hadn't thought of it that way.
Tailmaker
Post by Tailmaker »
This kind of a groove....tool path with VcarvePro and, as mentioned using lead-in and lead-out and leaving a little wood at the 4 corners as to not have the lid flying when finished.
https://youtu.be/hYZq2TecYB4
Using a thin kerf circular saw blade mounted on a 1/2" arbor.
