Unwanted tool path.
helensdad
Model of CNC Machine: Oozenest Ox 500 x 750/Openbuilds Minimil
Unwanted tool path.
Post by helensdad »
Hi, I am trying to set up to cut out the part in the picture from aluminium but for some reason it wants to join the two holes together, which I don't want. How can I stop it from doing this?
Re: Unwanted tool path.
Post by mtylerfl »
Please, will you post your actual file so we can help you troubleshoot?
carvebuddy.com
Post by highpockets »
Can you post the project file?
LOL!!!! Michael beats me again.... :lol: :lol: :lol:
helensdad
Post by helensdad »
OK, I actually deleted it, I am however having trouble still. I want to cut outside the line, but it says there are 12 unsuitable vectors. I will post what I have done. IThis is the first file I have tried to create myself...
helensdad
Post by helensdad »
Z laccutator finger.crv
(588 KiB) Downloaded 55 times
Post by scottp55 »
You just needed to Join those vectors.... lots of different ways, but Edit tab..select Open Vectors....Deselecting that bottom Polyline by holding Shift down..and then Joining them is good for Starters:) OH the poor cat:)
Z laccutator finger s1.crv
(587.5 KiB) Downloaded 47 times
helensdad
Post by helensdad »
Cheers Scott, many thanks. The poor cat?
Post by scottp55 »
No problem....I was actually putting off emptying my Dust Deputy canister and vacuuming behind the machine :)
WAY more than one way to skin that cat:)
Keep going...it get's easier!
Time to mask and goggle up :(
helensdad
Post by helensdad »
What went wrong?
What went wrong?
I got the tool paths sorted out but something went wrong when I tried to cut it. It cut the two mounting holes, nearly all the way through, then flew off to one side and proceeded to cut outside my piece of aluminium. When I ran the simulation in Cut2D it worked great. My machine did make a knocking sound before it developed a mind of it's own so maybe some obstruction caused it to miss a load of steps or something....
Post by scottp55 »
Post the file with toolpaths again, so somebody with a light machine can check speeds/pass depths and such?
"Knocking" sound, always seems to me like a Hard Stop was hit....It Always means steps will be lost! Virtually always the toolpath should be stopped by you immediately!!
I'm with Scott, it would help to see the file. From the picture it looks like you're using a v-bit. Also you machine isn't very ridge for cutting aluminum, loss of steps is a big possibility.
SteveNelson46
Post by SteveNelson46 »
Did you get X0 Y0 set to the same place as in the software?
helensdad
Post by helensdad »
Work zero was set before starting machine. I was taking 0.25 mm passes, aborted before pass had finished, using 1/8" endmill. I will post file tomorrow.... Many thanks all!
helensdad
Post by helensdad »
Part.crv
(115 KiB) Downloaded 54 times
Here is the file I ran that resulted in the mess in the above photo....
Your pass depth is set to 1mm not 0.25mm and, although I'm no expert on those type of machines, your feedrate is a lot higher than I've seen other people recommend especially at 1mm pass depth.
