I ran across this tab issue this morning and it's got me puzzled.
Reference attached file.
In toolpath Profile 1, I set tabs and no Allowance Offset in the Machine Vectors. It machines as expected.
In toolpath Profile 2, I set tabs and a -0.0625" Allowance Offset in the Machine Vectors. It again machines as expected.
In toolpath Profile 3, I set tabs and a -.125" (same as cutter diameter) Allowance Offset in the Machine Vectors. All tabs are machined out?!
As long as the cutter diameter is greater than the Allowance Offset the tabs machine as expected.
What am I missing here
Tab Anomaly
- highpockets
- adze_cnc
Re: Tab Anomaly
Hey John,
Odd one this. I checked and an offset of -0.112 works but -0.113 and less doesn't work so it's not just the -1 * dia that is a problem.
Steven
Steven
- highpockets
Re: Tab Anomaly
Seems a positive Allowance Offset works just fine no matter what the value.
- highpockets
Re: Tab Anomaly
Well, according to Vectric Tech Support everything is working as expected.... I don't understand how that can be, but that's the reply. Apparently you can have tabs with a positive Allowance Offset as far as you want, but if you have a negative Allowance Offset that comes close to or exceeds the diameter of the cutter the software determines you don't need tabs. Why I'm not sure. Don't understand what the Allowance Offset had to do with tabs.
- mtylerfl
Re: Tab Anomaly
Theory...
I think by offsetting at (or very close to) the diameter of your Bit, you are forcing the Bit to be “out of bounds” of the tab locations. Thus, they become “invisible” to the software and are ignored.
A solution could be just to create an Offset Boundary, Create your tabs as normal, etc.
- highpockets
Re: Tab Anomaly
Thanks Michael, but why would they be invisible in the negative and not in the positive?
Yes I can create an offset boundary, but now I've got two vectors to keep track up instead of using the "feature" of one.
Thank goodness I don't normally use tabs, this could drive me further NUTS!!!
- mtylerfl
Re: Tab Anomaly
I don’t know. Voo Doo, I guess?highpockets wrote:Thanks Michael, but why would they be invisible in the negative and not in the positive?
- highpockets
Re: Tab Anomaly
mtylerfl wrote:I don’t know. Voo Doo, I guess?highpockets wrote:Thanks Michael, but why would they be invisible in the negative and not in the positive?
As good as the answer I got from Vectric
- mtylerfl
Re: Tab Anomaly
- TReischl
Re: Tab Anomaly
A Wise Old Wizard Once Said:
"Those who tread in negative zones must be extra cautious, the penalty for overstepping is to cease to exist"
