Horses in Poplar
Horses in Poplar
The board is 24x11.25x0.73
Finish pass was with a 1/8" tapered ballnose at 9% stepover
Total machine time for rough, finish, and cutout was 3:43:36
- Model of CNC Machine: diy 4 X 4 CNC Router
Re: Horses in Poplar
Like it.
Was there a roughing pass?
What was the depth of cut?
Nice job.
mark-s
Nice job.
mark-s
- TReischl
Nicely done Randy!
Poplar is downright nasty, makes construction lumber look easy.
The roughing was only about 10 minutes since I limited it to where the finishing bit would be entering and exiting the material. The depth of the model was 0.46".
- SteveNelson46
Randall,
They came out really nice. Any particular reason you used Poplar?
It was cheap and readily available at the big box hardware stores.Any particular reason you used Poplar?
- Model of CNC Machine: Probotix Meteor 25 x 50
Randall,
I use poplar for the same reasons, and I haven't had any real problems like I have seen others post on here. I must be lucky. Horses look great to me. Thanks for posting them.
Dave
Dave
How do you get the milling time down so low?
Every time I calculate it comes out to about 8 hours.
mark-s
mark-s
It is a fast machine, and Gary and I have done a lot of tweaking to optimize 3D work.How do you get the milling time down so low?
Ok thank you
mark-s
mark-s
- WNC_Ed
- Model of CNC Machine: Shark HD4 AXYZ 4010
- Location: Western North Carolina - Heart of the Smokies
I thought that it looked like the Ultimate Dream Machine CNC from your rotary post the other day.Rcnewcomb wrote:It is a fast machine, and Gary and I have done a lot of tweaking to optimize 3D work.How do you get the milling time down so low?
The horses look fabulous.
Congrats.
Maker of sawdust
- gkas
I like....
- Model of CNC Machine: Thermwood CS-45 5 x 10
Take a small torch, to those fuzzes, them stiff brush,
Will Williamson willmade.com
Capac, Michigan
Capac, Michigan
