Rotary axis setup
Hivoltage
Model of CNC Machine: X-Carve 1000mm x 1000mm
Rotary axis setup
Post by Hivoltage »
I have an X-carve that I have modified with a 800w spindle (aircooled) and I use the G540 board for control. Mach3 for the software control
I bought my 4th axis off of ebay: https://www.ebay.com/itm/CNC-F-Style-A- ... :rk:1:pf:0
The features on that page are:
- Chuck type: 80mm self-centering 3 Claw Chuck
- Chuck center height?49MM
- Transmission ratio 1:6 (1200 pulses / revolution) synchronization gear reducer
- 3.5A 4 lead 57 stepper motor(1.8 Degree Step Angle)
- Stainless steel dust cover
- Processing load 30KG
- Anodized rust treatment
- 4-pin connector 1 = A +, 2 = A-, 3 = B +, 4 = B-
- Dimensions 170*200*90
- MACH3 setup instructions: 1 degree required Pulse
- The formula is: 360 / subdivision stepping angle * Drive * Transmission ratio / 360 = MACH3 Pulse
Everything on the X,Y,Z works with I am carving anything flat.
For some reason I cannot get the 4th axis to work properly.
I can get it to tune and it jogs. The issue is when I save the output from Vcarve the job rotates the part around multiple times.
When I look at the g-code it shows the A axis moving in the negative direction but more than 70mm as the work piece is 71mm circumference. (22.27mm diameter)
The g-code shows it going all the way up past -300.
What am I missing?
page1
page1
garylmast
Re: Rotary axis setup
Post by garylmast »
You may have already done this, but it may need calibration. Under Settings, click set steps per unit. The rest of the steps are pretty simple.
Gary
Hivoltage
Post by Hivoltage »
I did do the calibration. The job from vcarvepro turns the linear movement into degree rotations. In the g-code I can see that it never goes above 360 and when it runs up to 300 on one like the actual rotation of the part rotates 3 times. I have followed tutorials and used a excel sheet that is supposed to help. Nothing works properly. :/
Greolt
Model of CNC Machine: 900 x 750 2hp UCCNC Router & others
Post by Greolt »
Zero the A axis DRO
Enter G0 A360 into the MDI
If it does something other than exactly one revolution then the calibration is not correct
NormanAlbert
Post by NormanAlbert »
Have you gone in settings to set the radius?
ger21
Post by ger21 »
What do you have for steps/unit?
It should be 2000 x 6 / 360, which = 33.333steps/degree
