A Semi-permenant wood photo
nelaga
Post by nelaga »
I needed somthing that would last in the weather so after carving and mounting, I covered it with Epoxy Resin. Now it not only looks good but the wood is sealed. It Should last a while.Sorry about the clarity of the photos.
metalworkz
Model of CNC Machine: SX3 CNC, DIY 24x20 & 48x60 routers
Post by metalworkz »
Hello,
It looks very good. How long did it take to do the carving?
Best regards,
Wes
wes.spence@comcast.net
Gingery Machines:
Lathe, Horiz. Mill, Shaper, Leaf Brake
nelaga
Post by nelaga »
I did it on 1/2" Cabinet grade plywood. The size is approx. 8x10. I used a 1.4 " 60 degree V-Bit. And it took 3.2 hours at 60 IPM. :)
lovebugjunkie
Model of CNC Machine: Romaxx HS1
Post by lovebugjunkie »
Nice carving and I like the effect of the Epoxy coating, how thick is it?
george
nelaga
Post by nelaga »
Hi George,
I like the effect too. Its the first time I've tried it on a PhotoVcarve project. After this though, I'm sure I'll use it again. It looks like glass.
It is appox 1/16 " thick. :)
Thkoutsidthebox
Post by Thkoutsidthebox »
That looks great. :) Very nice.
I'm just wondering about the epoxies resistance to sunlight and UV....will it discolour and become opaque over time?
nelaga
Post by nelaga »
To tell the truth, I'm not sure about the long term effects of weather. The place that this one is used however is in a shaded area and will get minimum rain on it. The Epoxy is a commercial grade and has a non-yellowing agent added to it. I used it on a small table that has been on my screened porch and is has gotton rained on many times over the past 3 years and it still looks good. So I'm hoping for the best. :)
