Dovetail Gadget
MWinn
Model of CNC Machine: StepCraft 840
Dovetail Gadget
Post by MWinn »
Hello,
I have been trying for weeks to get the dovetail gadget to work in VCarve Pro 9.
When I create my sides and attemp to create my PINs I get the screen in the attached screenshot.
It always only creates one end of the pins in the correct spot.
Any suggestions would be appreciated.
thanks
MW
Re: Dovetail Gadget
Change the start node on the vector that is the wrong way round to be on the other end and that will sort it.
MWinn
Re: Dovetail Gadget
Post by MWinn »
Ah, that was the culprit,
tyvm
MW
fredfow3
Model of CNC Machine: Laguna Swift 4x4, Shapeoko S3 XL
Re: Dovetail Gadget
Post by fredfow3 »
Just a tip,
If you make the boxes and use the "Explode Vectors" gadget on them, it will make all the start points correct.
Cheers,
Belgard
Model of CNC Machine: shark extended bed 8.5
Re: Dovetail Gadget
Post by Belgard »
So, on my dovetail gadget, it is inserting the pins backward or facing outward. I am following the tutorial to the T, and its just not inserting them correct... help
Re: Dovetail Gadget
Belgard wrote:So, on my dovetail gadget, it is inserting the pins backward or facing outward. I am following the tutorial to the T, and its just not inserting them correct... help
Have you changed the start node position?
Belgard
Re: Dovetail Gadget
Post by Belgard »
no, apparently not. How do I do that?
Re: Dovetail Gadget
Go into node edit mode (press N) click on the vector and you'll see a green square at one end. Hover over the black node at the other end of the vector and press P to make that the start point. Rerun the gadget.
Belgard
Re: Dovetail Gadget
Post by Belgard »
thank you. it works!!!!!
