Chamfer Radius Gadget - New Gadget
Jennifer
Model of CNC Machine: 1000 x 750mm CNC router 3axis
Re: Chamfer Radius Gadget - New Gadget
Post by Jennifer »
Hi,
I have been wracking my brain trying to figure out how I can make a radiused fretboard using vcarve pro. Basically it is a long narrow rectangle with the top surface curved. Will this gadget allow me to effect that?
Jennifer
You would need a 3D model of the shape you want or you could try the moulding toolpath.
Sawnsand
Model of CNC Machine: Probotix Meteor
Post by Sawnsand »
I did some asking about an issue with Vectrics Chamfer gadget, and they did a new upload on their gadget collection to fix the issue. I also asked about the Chamfer Radius gadget that I got off this forum last year.. here is that exchange
Mark Moran (Vectric Ltd.)
Jan 2, 14:47 WET
Hello Craig,
Thank you for the follow-up email.
I am afraid that we would not be able to amend a gadget that we have not written.
You would need to get in touch with the author to see if a later version is available.
Regards,
Mark.
Mark MORAN
Support Manager
Crc
Jan 2, 14:38 WET
Thank you for the quick response, I'll look into it when I get home after work.
There is another gadget that has an odd situation. It's called Chamfer Radius, and I first downloaded it from the Vectric Forum a while back, it's not available from the Vectric gadget collection. It was while I was using the previuos version of Vcarve Pro, 8.5 I believe. I had it set up and used in a number of files that I transferred over to 9.0, and they work fine, unless I recalculate all the toolpaths in one of those files. ReCalculating one or more of the toolpaths other than the Chamfer Radius toolpath works fine, and the Chamfer radius toolpath stays in working order, as long as I don't recalculate it.
It seems to work as a holdover on files originally set up in Pro 8.0/8.5 and used in 9.0... but it will not work when installed in 9.012 and creating a new toolpath. I get an error message that some lines of code are not good...(I don't have the error in front of me, I could send it if needed.)
I know this is not a Vectric gadget, but if there is someway to make it work in my current version of V Carve Pro, I would appreciate it...
_________________
I do use this gadget and if it could be fixed to work in VCarve Pro 9+, I would be very grateful...
Craig C.
SteveNelson46
Post by SteveNelson46 »
I installed this gadget in Aspire V9 and I can't seem to make it work. Maybe I'm missing something? I think it needs to be modified for use in all of the V9 versions.
EDIT: It does work in V 8.5 though.
Sawnsand
Post by Sawnsand »
Here is the Vcarve pro message I get when I try to apply the Chamfer Radius gadget. The gadget starts fine and lets me pick the option I want, hit OK and this is what shows up
Jeff needs to change his gadget to work with the latest version. It's not a Vectric gadget.
BallardMillworks
Model of CNC Machine: Shopbot Buddy
Post by BallardMillworks »
Any chance of an update? I tried and get same error posted earlier.
This would be wonderfult to have!
paricklesher
Model of CNC Machine: CNC Router Parts Pro
Post by paricklesher »
Hello,
Is there any way it could get upgraded to work with v9 or v9.5?
I would be willing to donate some money.
Jeff hasn't been on the forum for a while.
I've changed the lines in the gadget that stopped it working in the latest versions. I don't like amending other peoples code but Jeff appears to have gone awol.
It can be installed using the instructions Jeff posted on the first post of the thread or you can rename the zip file to vgadget and install by double clicking the file or the Install Gadget item in VCarve/Aspire.
Chamfer In and Out.zip
(57.35 KiB) Downloaded 261 times
paricklesher
Thank you very much!! It seems to be working now from my quick test.
badgersurfer
Model of CNC Machine: xcarve
Post by badgersurfer »
Adrian wrote:I've changed the lines in the gadget that stopped it working in the latest versions. I don't like amending other peoples code but Jeff appears to have gone awol.
Slightly confused here. I downloaded your modified gadget and placed in the correct location but when I run it in Vcarve Pro 9.5 is just comes up as a Chamfer Tool and not a Chamfer Radius tool. Any ideas?
This is the radius version. The postings got mixed up somewhere along the line.
Chamfer Radius.zip
(162.57 KiB) Downloaded 176 times
tuffduck
Model of CNC Machine: CNC Conversion Kit
Post by tuffduck »
Hello, has anyone updated this for version 10? Thanks
tuffduck wrote:Hello, has anyone updated this for version 10? Thanks
This version should work with V10. Install manually or rename the zip file to vgadget to install via the Gadgets menu or double click.
Chamfer Radius.zip
(162.5 KiB) Downloaded 55 times
