my circles arent circles
thephridge
Model of CNC Machine: Home built Gekko 540 driver. 4' 8' bed
Post by thephridge »
I draw a circle in here and transfer over to mach4 and run the operation and it dose not cut a perfect circle!? sorry we are noobs over here so this may sound dumb. Any help would be awesome
Mike-S
Re: my circles arent circles
Post by Mike-S »
Did you calibrate X & Y? If you profile "on" a 5" x 5" square with a shallow cut V-bit, does it measure 5x5?
thephridge
We calibrated using the mach 4 built in system. We had good luck initially but something has changed somewhere. We tightened all mechanical adjustments so we're good there. Can you expand on "on"? LOL.
Mike-S
Post by Mike-S »
Profile cuts can be "on," "inside," or "outside" the vector. I'd still try a square of known size to see if you get a true square.
IslaWW
Post by IslaWW »
If your machine has been calibrated properly and your preview looks as you would expect, this is most assuredly a machine issue. Try cutting the file at half the feedrate and see if the results get better
GCnC Control
thephridge
Thanks Mike. Gary...the previews look a little out of shape to me. Thats just making an ellipse and making it vector. It appears to have slight variations in the curve here and there. I thought there might be a setting that would smooth it out.
thephridge
And we slowed the feed rate way down.
is this a circle you have drawn yourself using the software or one that has been auto traced as part of something else?
If you enter node edit mode how many nodes does your circle have? :lol:
If you post the file then someone will check it for you :lol:
thephridge
here is just the circle usually we cut multiple at one time, our goal is to cut a 4by4 sheet of circles at one time. we keep getting indents and other imperfections in the circle same on every single one. usually it shows up where the tabs are, i have ran the machine in the step calculator in mach 4 and the machine is running perfect if i tell it to move so many inches it moves exactly that, on every axis :roll:
3inch circle.crv
(19 KiB) Downloaded 187 times
IslaWW
Post by IslaWW »
If you are getting deflection in the tab locations, this is for sure an issue with the machines rigidity. There will always be a reduction of edge quality when the z axis moves vertically, but it should be minimal.
Check for something loose in the axes. If nothing is loose, then you may simply be bending something
GCnC Control
thephridge
here is another file is just tried cutting again checked my machine its tight no sloppy play in it at all. we also removed the vacuum hose to reduce any kind of variable and still have the same issue.
3 inch circle.crv
(160 KiB) Downloaded 202 times
IslaWW
Post by IslaWW »
There is nothing wrong with the file. Post a picture of the results
GCnC Control
It is 100% not the software. Think about it. If it was the software there would be hundreds of people posting here with the same issue if there was something that fundamentally wrong with the software.
Try reducing your pass depth or ramping into the cut. 0.3" in one go with a 1/8" bit might be too much. I certainly wouldn't cut that deep in one pass without a ramp in anything but the softest materials with a bit that small. It's almost certainly deflecting.
thephridge
this is one we just cut with a ramp in and slower feed rate and set to not cut as deep still same issue with tabs
Leo
Post by Leo »
Whatever is wrong - it IS absolutely IN the machine - NOT - the program.
There are only 4 nodes on the circle and the program CANNOT generate the effects you have in the picture.
There is something going on in the machine. Looks like uneven forces causing deflection.
A machine cannot be called rigid by virtue of shaking it with a hand, and it "feels" good.
You need to measure it at many different points with an indicator to measure the movement - possible with a fish scale or something similar to measure force applied and indicator to measure movement and any given force.
