Routing dimensions off
erikwinkler
Post by erikwinkler »
Hello,
Somehow somewhere my settings were changed.
When i save toolpaths for my Multicam 3000 router .cnc files; now suddenly the files that should be 100mm high are routed in about 10mm high.
How could this happen, and how do i resset this?
To be honoust i tried a few things and now forgot which post processor language i used to use.
It was one of these Multicam .cnc scripts (and i tried both of them):
1. MultiCam G Code (inch) (*.cnc)
2. MultiCam G Code Arc (inch) (*.cnc)
I use Aspire 4.015
If anyone could help me, i am lost out of possibilities here.
Thank you.
Re: Routing dimensions off
When it's that far off it's usually a mismatch of metric to imperial. You're talking about metric sizes but picking imperial processors. Are you sure you weren't using a metric one before? What units is your machine set to work in?
erikwinkler
Hello Adrian,
Thank you for your reply.
I am sure it has to do something with this problem, the machine is in metric, but i can not find a post processor to save my toolpaths in a cnc file for a MultiCam router anymore...
I think i used the metric processor, but somehow it is gone out of the list.
Mark
Model of CNC Machine: CNC Shark, ShopBot, Roland PNC3000
Post by Mark »
Hello Erik,
Please drop us an email to support, we can test your files out for you.
Many thanks in advance.
Cheers,
Mark.
Verucktjim2
Model of CNC Machine: Multicam And Desktop pro
Post by Verucktjim2 »
Hello
I was wondering if you fixed this problem? I am thinking about getting Aspire for our MultiCam 3000 Router.
What if any setting do you need to change?
I did run a sample program from Aspire demo ver 9
But it wanted to start cutting at the other end of my 12' table. Not home position.
I use enroute right now.
Thank you
The original poster (Erik) hasn't been on the forum since November last year.
Have you been through the tutorials for setting up a job? Where did you set the XY home positions in Aspire? Which Post Processor are you using?
erikwinkler
I fixed the problem.
I did manny things and suddenly it worked again, because of that i do not remember exactly what it was.
I reinstalled everything and configured the settings again, it was my mistake probably that i changed something that i shouldn't have done.
Will post some new projects i did.
