Cuts right line twice.
sailfl
Model of CNC Machine: MechMate
Post by sailfl »
I have never seen this problem in all the time I have used Aspire. The right line cuts twice when using outside and inside machine vectors. Only once when on machine vector is used. I would like to understand why it is doing this.
I am still using 4.5 version.
Save Test.crv3d
(18 KiB) Downloaded 70 times
Re: Cuts right line twice.
If you go into node edit mode and drag the bottom node over on that line you'll see the problem. It's basically a double line as far as Aspire is concerned because of the overlap.
Post by Rcnewcomb »
If you zoom in enough you see the line has an extra point.
(Adrian beat me to it!)
10 fingers in, 10 fingers out
another good day in the shop
Post by TReischl »
The dreaded Double Line Whammy!
sailfl
Post by sailfl »
Thank you. I knew it was a problem but I could not find it. It is very small.
Xxray
Post by Xxray »
TReischl wrote:The dreaded Double Line Whammy!
I'm singin those Double Line Blueeeeesssss !
Post by TReischl »
"Nobody leaves til dey sing da blues."
fixtureman
Post by fixtureman »
TReischl wrote:"Nobody leaves til dey sing da blues."
Is'n that a line from Adventures in Babysitting
Post by TReischl »
You win the prize!
