I have only been learning CNC for a couple of years and just use it for hobby work at home. I have a Chinese 6040 Router.
In that time I have been using Cut2D 1.5.
I see that Cut2D Desktop 8.5 seems to have taken over from my software.
In your opinion, is it a good move to upgrade to the new 8.5 software? The only drawback I can see is the size restriction, but I don't think that will affect me.
Any other reasons not to?
Upgrade from Cut2D 1.5 to Cut2D Desktop 8.5?
Re: Upgrade from Cut2D 1.5 to Cut2D Desktop 8.5?
Steve, don't run cut 2d myself (started with it but upgraded to Vcarve pro because my needs changed) but the best way to tell if it would be a good move for yourself is to download the trial version & see for yourself, the upgrade price I believe depends if you go for the desktop or pro version, the pro version doesn't have the size restriction plus it has some other features like being able to use gadgets & nesting.
This link will tell you what is new in 8.5 but really the best way is to download it & take it for a test drive
http://www.vectric.com/products/cut2d/WhatsNew8.html
8.5 is a huge upgrade compared to 1.5, many more features and drawing tools.
- Model of CNC Machine: X6-1500GT re-built with ESS and MB2
Thanks Guys. I've read all the blurb but I find it hard to determine what features I will need.
If 8.5 is a natural progression, I think I will do the upgrade.
- JamesB
- Vectric Alumni
Hi Steve,
As Martin said, your best bet is to download the trial version and spend some time working with it to see what it will offer you before you pay for the upgrade. That way you can be sure it's beneficial to what you use the software for.
Trial can be downloaded from this page:
http://www.vectric.com/products/cut2d/trial.html
Cheers
James
Cheers
James
Thanks lads. I just found out that its a free upgrade..woo hoo!
I guess, as long as the size restriction isn''t a problem ( don't think so ) then any improvements will make it worth while doing.
