Coat Of Arms - "Aspire"-ing to improve all the time
- Model of CNC Machine: 4Axis Router
Rhodesian Teak with Gold leaf and Antiquing gilding paste.
The model build was a lovely challenge. Still lots of room for improvement though!!
Hope it gives someone "Aspire"-ations!
Cheers Kevin
- highpockets
Re: Coat Of Arms - "Aspire"-ing to improve all the time
Great job Kevin.
Is this one piece carved are did you carved the pieces gild them and apply them to the plaque?
Thanks for that.
It's one piece cut with a 20deg vbit
FANDYTASTIC
Looks great
Looks great
- Makingtoothpicks
- Model of CNC Machine: Cncrouterparts CPR2448
What is the overall size of this. You used a 20 deg V bit. At what depth. How long did it take. It is very nice.
Don
Don
Thanks Don
420mm wide x 594mm high (A2)
Highest point is 15mm
6,5 hours total carving time and another 10 hours of hand finishing
- Makingtoothpicks
I like heraldry also. You inspired me to try one. I will be doing it soon. Funny I came up with about the same size as you. 16"x20". I am showing running time at about 16 hours. Lets see what I get.
You need to increase the feeds and speeds of your hand finishing. jk LoL
Don
Don
Would you please post the aspire code used to make this project. I would like to try this and would use your Aspire code as a starting point. I have done smaller similar things in the past but my carving times were much longer, as much as 18 hours, so you must have a better mastery of Aspire than I do.
Wayne K
Littleton, CO
Wayne K
Littleton, CO
I like very much your beautiful artwork, congratulation. But less then 7 hours of carving with a Vgroove 20 degree with all your components and a maximum depth of 15mm it impossible for me to do that. I would like your secret. I had done a simulation of a part of your work(without florish and helmet) and it took more then 8:30 hours:
Just to groove witn a end mill .25 F:100 Pl:30 stepover 25% Pocket 1
07:16:21
Banner 3D Finish 1
00:18:41
Lion 3D Finish 2
00:55:44
I like that kind of work but I spent a lot more time. 99% of my artwork are only for gifts but it's not a raison to take a lot more time to do it.
I wonder where you purchased your Vbit because I have many, but it is not robust enough to make cuts up to 15 mm.
I hope receive some information and hints. Excuse me for my English I am a french Canadian and I need more practice to write better.
07:16:21
Banner 3D Finish 1
00:18:41
Lion 3D Finish 2
00:55:44
Overall roughing was first done with a 6mm ballnose 6mm per pass with 2mm tolerance,
and the the 3d finishing is done wit 20deg vbit with a 0,1mm stepover at 24000rpm 6kw spindle at 5000mm/min
- Creation in Wood
- Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
