Speaker wizzer cone
calgrdnr
Model of CNC Machine: ShopBot prt with 4g upgrade
Speaker wizzer cone
Post by calgrdnr »
Need to reform center wizzer cone thinking 3 parts 2 inner 1 outside
How would you do it ? yeah it late hoping someone else tackles it before I awake :)
bought the drivers want to figure out repair then use for DIY speaker :)
Thanks for reading
Kent
Ms Wolffie
Re: Speaker wizzer cone
Post by Ms Wolffie »
What on earth is a speaker wizzer cone :?:
Cheers
Wolffie
Whatshammacallit
calgrdnr
Post by calgrdnr »
The cone that protrudes out of the in the center that is bent out of shape .
Just like my belly in the middle... unlike me I think simple mold 3 parts might enable me to
reset it to its original form :)
its suppose to smooth out frequency from the driver/speaker
thanks for reading Kent
Ms Wolffie
But isn't that one made from some kind of fibre?
Cheers
Wolffie
Whatshammacallit
calgrdnr
Post by calgrdnr »
it is made from paper. figure I would get it moist reshape let it dry back out or make another either way a form would be good . :)
sailfl
Model of CNC Machine: MechMate
Post by sailfl »
Don't they sell the cone?
If you wanted to you could make a cone by milling it and then fitting the old one over it or slip the cone into the existing paper. I would be concerned of damaging what is around it.
metalworkz
Model of CNC Machine: SX3 CNC, DIY 24x20 & 48x60 routers
Post by metalworkz »
Kent,
From the looks of the speakers you might be able to get away with just an internal cone to form the wizzer when wet as the base is trapped below and it seems if you only wet the damaged areas the internal form would push them back into shape without an external form. Never tried anything like this but perhaps that could be attempted and if needed then the external form could be made? Good luck with this and keep us informed what you end up doing and how it works.
Wes
Best regards,
Wes
wes.spence@comcast.net
Gingery Machines:
Lathe, Horiz. Mill, Shaper, Leaf Brake
calgrdnr
Post by calgrdnr »
Thanks for the idea Wes. I won them on ebay waiting to get them then will give it some more thought. might cut it off reshape and then glue back .
sailfl the speaker/drivers are from the 70's I doubt can get exact replacement . I always try to keep everything original if I can .
they will more then likely end up in a DIY speaker setup mishmash of drivers from different speakers I happen to have extras of .
kyeakel
Model of CNC Machine: Camaster Stinger I, Shopbot PRT 9648
Post by kyeakel »
I wonder if you could use a fabric steamer, that way it won't get too wet or take long to re- set the shape?
Kipp
CAMaster Stinger 1
Shopbot PRT 9648
Aspire 8
Cut2d,Cut2dLaser
