and the winner is
and the winner is
I was commission to do a Golden Oscar statue, for a reward evening for a company that do event.
The finish statue was 84'' tall made with white styrofoam .It took over 40 hours of cutting
using Aspire slice of 2'' thick.
Coverd with Styrospray 1000 ( I love this product)
Forgot to mention that i bought the design from ''Creativecrash.com
I covered with yellow paint from Behr
and finished with Gold acrylic from Modern Master.
Gerry
Gerry
I rather be the leader,than the follower
- ChrisInEstes
- Model of CNC Machine: Vytek 4' X 8' - Perske Spindle - Mach3
Re: and the winner is
Wow... That's got to be at least close to a Vectric record!
At least 42 slices... How about some pictures?
Chris
Chris
- customquint
- Model of CNC Machine: AXYZ
Cool, great work!
- Ms Wolffie
I don't think so, Chris.ChrisInEstes wrote:Wow... That's got to be at least close to a Vectric record!
Chris
Rather like it is a large machine bed.
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- ChrisInEstes
Ha! I was only 90 degrees off...Ms Wolffie wrote:I don't think so, Chris.ChrisInEstes wrote:Wow... That's got to be at least close to a Vectric record!
Chris
Chris
- dealguy11
Hi Gerry -
That looks great. I'm about to do my first Styrospray 1000 project on some corbels. Did you brush, roll or spray it on?
Hi
I have use a foam brush for the first coat after it was dryed i used a regular brush .
Make sure the first coat covers all the small details then it is a question to put more layers
for adding strenght. It is a very good product and drying time like they say.
i have started from the top down and by the time i arrived at the feet the top was almost dry
for a second coat. At horizontal it settles by itself but for the vertical watch the runners you will
prefer to put some small layer.
If i had more time for that project i would have covered it with more coats.
Hope it answer your question.
My CNC is 48''x96''
My CNC is 48''x96''
- Model of CNC Machine: salecnc XJ1224
That is one cool project.
Brian
Brian
- zeeway
Awesome.
Angie
Angie
to finish the subject here is a picture of what the customer did with it,
they place it at the entrance of the room and then move it inside on the stage.
- Model of CNC Machine: Shark Pro HD and CNCrouterparts 4896
oooo that is very cool. Have to explore that slicing process. Was it sliced from a true 3 D model? Curious how Aspire dealt with the front half and the back half.
- Model of CNC Machine: shopbot buddy bt 32
Very cool project . How long did it take in total ? pop's
POPS1964
SHOPBOT Buddy BT-32
SHOPBOT Buddy BT-32
