Flat area in bottom of cutout.
JimmyD
Model of CNC Machine: ShopBot PRSalpha, custom rotary indexer
Post by JimmyD »
The bowl shape in the photo is 18' x 18" x 6" thick. The concave cutout is 5" deep. The concave cutout was made by using the "create shape from vector" tool.
Does anyone know how to put a flat area at the bottom of the concave cutout?
Thanks in advance for any suggestions.
Re: Flat area in bottom of cutout.
Setting a limit height value when you create the shape should do it.
mezalick
Post by mezalick »
Adrian’s correct, the limit to height option will give you a soft flat bottom ( see attached picture )
If you want a sharp flat bottom, just add another flat component and raise it to where you want.
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
Post by mezalick »
Michael
Michael Mezalick
mm@mezalick.com
JimmyD
Post by JimmyD »
Thanks very much!
mezalick
Post by mezalick »
In my universe, there are three answers to every question.
While having an adult cocktail with my wife this evening , this question started to burn a hole in my forehead...
So, for my third way you could use a the two rail sweep..
I know,,it’s not efficient or even “ easy” but it can be done..
Michael
Michael Mezalick
mm@mezalick.com
JimmyD
Post by JimmyD »
Glad to hear that I am not alone in my never ending thoughts of how to solve a problem.
Again, thanks very much
PaulRowntree
Post by PaulRowntree »
Or use a fluting toolpath. This works in VCP too.
Paul Rowntree
Post by mtylerfl »
Many ways to skin a cat. Here's another way, just for fun...
1) Dome -Subtract
2) Full-Depth Block - Add
3) Partial Depth Block - Merge
carvebuddy.com
