Maloof style rocker
rscrawford
Maloof style rocker
Post by rscrawford »
Finally finished creating the files for a Maloof style rocker. Been working on the files for a year or so, trying to convert one of the rockers I hand carved several years ago into models and cut files. I'll post pics of the jigs and methods I used later.
This is the rocker I used as the 'template'.
Here are all the parts laid out, ready to be 'assembled'.
Just a little sanding left
Fresh coat of finish. Love the look of dark walnut.
Russell Crawford
rsetina
Model of CNC Machine: Shark HD 2.0
Re: Maloof style rocker
Post by rsetina »
You made this with a CNC machine? Not all of it, did you?
Rick
Shark HD 2.0
rscrawford
Every part except the rockers and the back slats. Those I laminated on forms cut on my Cobra.
The legs each had one dado cut on the table saw. One side of the back legs was rounded over on the router table. The back slats and rockers were rounded over on the router table. Other than that, everything was cut on my cobra.
Russell Crawford
rscrawford
The armrests were the hardest to design in Aspire. A very organic shape. Two sided machining in Aspire, using dowels to index.
Top view
Top view
bottom view
bottom view
Russell Crawford
rscrawford
The back legs were a bit tricky, because they angle up towards the headrest. Had to cut them on a tapered jig so the joints would cut correctly.
Russell Crawford
rscrawford
Didn't take pictures of the head rest being carved, but here are pictures of the model (two sided machining with dowels to index, then a third side machine for mortises)
Russell Crawford
PaulRowntree
Post by PaulRowntree »
This is magnificent workmanship Russell, and a beautiful chair to boot. The time and thought that you invest in planning these projects really shows well. Projects like this are the perfect antidote to folks who think that CNC is all about mass-production, and not craftsmanship.
Paul Rowntree
WoodEraser
Model of CNC Machine: Shark Pro Plus
Post by WoodEraser »
WOW !!!
That is awesome. You put in alot of time and thought into that project.
Thanks for sharing.
Eric
The WoodEraser
Liberty Twp (N. of Cincinnati & S. of Dayton) Ohio
armbrusterco
Model of CNC Machine: Roland MDX-40A
Post by armbrusterco »
Beautiful results with excellent craftsmanship, which we always see in your work. Thanks for sharing, Russell.
Bob
Bob Armbruster
www.ArmbrusterCo.com
rej
Model of CNC Machine: 2014 roc-tech 4x8 with servos
Post by rej »
if you ever do a 2 or 3 day workshop teaching this, i'd like to attend. that's one of the coolest projects I have seen on this forum. it amazes me how people can figure it all out. beyond impressed on this one.
http://www.3dsigncamp.com
http://www.roctechusacnc.com
rsetina
Post by rsetina »
I'm am totally amazed at your work. I've seen Maloof's rocker at a show in Pomona at the fair grounds. Beautiful! This is just as amazing.
Rick
Shark HD 2.0
Post by TReischl »
Incredible! Nicely done!
How soon do you post all the files up here? Huh? Huh? Ok, I will not hold my breath. . . .
zeeway
Post by zeeway »
Beautiful work. Love Maloof anything. You are my hero.
Angie
Strat
Model of CNC Machine: Laguna IQ CNC / HHC
Post by Strat »
Hats off to you, WOW!
endgrainguy
Post by endgrainguy »
Really exciting work! What kind of production do you have in mind? Any rough estimate of machine time per chair? Thanks for showing us!
I thought this was supposed to make life easier?
