lil help please
- Model of CNC Machine: Two machines, CRP 48x96 and a xylotex
lil help please
Hey I'm trying to make a small leg for a box. The dimensions dont have to be exact. Having issues creating the 3d component, any help would be cool. Thanks
- TReischl
Re: lil help please
Hard to tell what problems you are having from your post.
- Mike-S
Re: lil help please
What should be simple is deceptively difficult.
Did this by designing in another CAD programming and importing into Aspire as an .stl file.
I don't see how to do this in Aspire alone.
Re: lil help please
Is this the sort of thing you are after ? This can be done in Aspire4 or VCP7 using Fluting toolpaths ... It could start and end as almost any shape you want (I think)
Paul Rowntree
Re: lil help please
The two rail sweep will easily create the 3D model. The challenge will be getting good results machining the near vertical sides with 3D toolpaths.
Tim
Tim
Re: lil help please
Thanks guys, hope you saw the slight difficulty I was having.
Re: lil help please
If you want to try the Fluting toolpath route, there is a new "Cookie Cutter" gadget that might be useful for this type of work.
http://forum.vectric.com/viewtopic.php?f=2&t=19279
Cheers!
Cheers!
Paul Rowntree
Re: lil help please
Thanks Paul, appreciate it.
