Lines in 3D Carvings Resolved
zeeway
Post by zeeway »
About six months ago, I started seeing a series of lines in my 3D carvings. Everything I tried failed, until I tightened up my rack and pinion drives. So if you have drives that look like this:
...suggest you loosen the motor bolts and pull that little belt tight...
....and the problem is resolved. I do not know if the belts stretch or the bolts loosen over time, but my suggestion is to do this every few months.
Angie
Woodbutcher-59
Model of CNC Machine: Homebuilt 3'x5'x6"
Re: Lines in 3D Carvings Resolved
Post by Woodbutcher-59 »
Hi Angie,
Thanks for the heads up....
I use those R&P drives and never really thought about the belts.
I'll have a look next time out to the shop !!
I have had a tensioner vibrate loose, so watch those as well.
Jeff
Aspire 12
Mach 3
" I'm tryin to think but nothin happens " - Curly Howard
ChrisInEstes
Post by ChrisInEstes »
I'm blaming Angie for this! :lol:
Yesterday while routing, I think I thought I heard a clunk when the X Axis changed directions once in a while, but I wasn't sure, and the routed stuff coming off the machine looked great. Well, after I was done routing last night, with the steppers still powered up, I gave the gantry a couple nudges, and the far side had probably 1/8" of movement. I'll dig into it this morning, and hope it's just something loose, not something broken!
Wish me luck!
Chris
ChrisInEstes
I forgot to ask... were your lines parallel to the direction of machining, or 90 degrees perpendicular to the machining direction?
Thanks!
Chris
zeeway
Post by zeeway »
Chris,
My lines were 90 degrees to the direction of the feed. (I didn't touch your machine, I promise :D ).
Angie
ChrisInEstes
I have lines like that... or maybe like that since I don't know what yours' look like. I can mostly just see them and not really feel them, but I can feel a few.
Thanks!
Chris
zeeway
Post by zeeway »
And so it begins....(cue Jaws music...)
Angie
