Vacuum Failure on an otherwise lovely project
Gallery for samples created from Vector Art 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
rscrawford
Re: Vacuum Failure on an otherwise lovely project
Post by rscrawford »
I just bought some Raptor composite nails and the Omer gun and this works really well to hold stuff in place if you don't have enough vacuum. I don't need to worry about hitting nails because they cut easier than wood.
Russell Crawford
Ms Wolffie
Post by Ms Wolffie »
rscrawford wrote:I just bought the Omer gun
When I first saw this I thought you meant a spear gun and my mind boggled :lol:
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
John Murphy
Model of CNC Machine: AXYZ 5010
Post by John Murphy »
That's an excellent idea Gerald. I've used 18 gauge, but ever thought of getting the 23 gauge pin nailer out.
Now I'm gonna have to try it. Thanks for the tip!
backyard_cnc
Model of CNC Machine: SHOPBOT, LIGHTMACHINES MILL, AJAXCNC-KNE
Post by backyard_cnc »
No problems John, thats what forums are for. They make us look at things we already knew differently. I ran a few router bits thru some 23gauge pins as a test with no visible damage but I still try to place them where I am less likely to go thru them. Bits is expensive! , but then I guess many things about this past time/hobby or business is expensive to a point. I like the fact that the 23gauge pins hold good but still can be pulled out from the backside once the material is pulled from the table and leave the slightest of holes that will generally fill with paint and disaapear if they are within the model.
cheers
gerald
