I broke a bit in the middle of a piece. Can someone tell me the steps to restart? I have not moved the router. It is still setting where the bit broke. I am using Aspire and WinCNC. I have saved my home position. I am a real newbie so I need step by step instructions. If this was a simple design I would just start over but I have several hours into it.
thanks for any help.
Kathy
broken bit in the middle of carving
- Ms Wolffie
Re: broken bit in the middle of carving
I am by no means an expert but, if you know what line you were up to, can you delete the part that has already been done and start from there?
That's how my sewing machine works.
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Xxray
Take note of the line #.
Up at top of WinCNC, the file/edit ect clickers that give you options, you'll see a restart file option.
The aborted file should be there, back if off 100 lines or so ... When you put in a new bit, obviously you will have to remeasure the tool. I'd re-initialize the machine as well, in case the drag from the broken bit caused it to lose position. Don't worry about leaving it at the exact same spot, you'll have to move it to get the new bit in anyhow. Once thats done, you should be able to restart the project close to where it aborted, hopefully with good results.
- mezalick
Kathy,
Did you resolve the problem.
The answers here and on the Camaster forum are correct.
It's just like re-starting a file
Give me a call if you are still having problems.
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Thanks everyone, I will give this a try tonight after I get home from my day job.
You are so helpful. Hope everyone is okey on the East Coast.
Kath
Kath
- Model of CNC Machine: Cam Master StingerII
Re: broken bit in the middle of carving still do not get it.
I am missing something. I have watched the videos and read all the posts on this topic I can find.
I have the starting point marked on my board, written down and saved ....
I initialized my machine,
did the touchtop,
measured the tool,
recalled the project and entered the line #
when I hit the enter key to restart my computer goes out of the program looking for another file?????
I am at my day job now but any suggestions would certainly be welcome.
Thanks Kathy
did the touchtop,
measured the tool,
Thanks Kathy
Embroidery - WingsXP
