Speedsand Feeds red oak
Moderator: Todd Bailey
I am trying to carve some red oak with a 3d model and am getting some burning. Should I slow down the speed or the feed or both? I am using a 1/2 inch ball nose for roughing.
Re: Speedsand Feeds red oak
Kimon I've never cut but a small amount of red oak but I did get some burning in maple.Kimon wrote:I am trying to carve some red oak with a 3d model and am getting some burning. Should I slow down the speed or the feed or both? I am using a 1/2 inch ball nose for roughing.
I ran another pass at mach speed at a depth just enough to get some chips and it cleaned it right up with no burning.
So, like Jason said, faster feeds should clear it up.
- Thkoutsidthebox
I think you should have increased the 'FEED' not the 'SPEED OF THE ROUTER'. The more router speed (rpm), then the greater the heat generated due to friction and the more chance of burning. Slowing(Decreasing, not Increasing) the router speed (rpm) will decrease heat.
The faster the 'Feed Rate', then the shorter time the bit is touching one place to generate heat, and the less heat, and hence less burning.
