Hello, I'm trying to find a tutorial on, How to make a Detailed 3D Relief Model of a Child's Photo for carving with the CNC.
Hoping that someone can point me in the right direction.
Thank You
Creating a relief model from a photo
- Model of CNC Machine: Openbuilds Workbee 1010 modified
- SteveNelson46
Re: Creating a relief model from a photo
You’ll need Aspire to do that. See this post for making a “Santa Claus” from an image by Michael M. to see what you’re up against.WoodsmanL56 wrote: ↑Wed Jun 22, 2022 11:47 pmDetailed 3D Relief Model of a Child's Photo for carving
I can't tell if you have PhotoVCarve or are trying to use a photovcarve tool path in VCarve? If you have the PVC program, you can make a reasonable approximation of a relief model, especially if your photo has good contrast. Using techniques similar to making a lithophane, you can do the same thing in wood and your eyes will process it as being full 3D. However, you won't be able to edit/model areas of the output such as making a cheek fuller/deeper.
