Depth of cut and Spacing
SGold
Model of CNC Machine: Stepcraft D-840
Post by SGold »
Hello Everybody,
I recently purchased the Photo VCarve software, but have not been successful with it. Can every please share some tips and tricks so I can figure out what I did wrong! I have watched a bunch of videos, but still unsure what I need to change. My issue is how to know what depth to carve and the line spacing
TIA!
I have attached a few phots. I attached a photo of the preview, how the project actually came out, my tool settings, and the cut settings.
Re: Depth of cut and Spacing
Post by mtylerfl »
Quick question for you regarding your v-bit setting...
Are you using an actual 45-degree bit?...or are you using a 90-degree bit?
Your bit setting shows you are using a 45-degree included angle (aka, total angle) bit.
GEdward
Model of CNC Machine: 24 X 36 3 Axis
Post by GEdward »
It appears to me that you are using a narrower angle, perhaps 30°, V-bit. The darkest areas of the carve should have the grooves almost touching or even overlapping a little bit. If a 45° bit cuts to a depth of 0.05 in. then the width of the groove would be 0.0414 and the line spacing is 0.041.
Ed
whubauer@t-online.de
Model of CNC Machine: CNC Step 720
Post by whubauer@t-online.de »
Nimm einen 1mm Rundfräser,Linienabstand 0,15mm
Tiefe zwischen 2-max 3,5mm
dauert etwas länger aber wird super
LG Werner
