Greetings, hope all is well with everyone, haven't posted in a while.
Did this 10x6" litho for the daughter of a deceased friend, RIP Bro John. Don't know why it cut through, rarely ever happens to me and usually .21 max depth is fine, but thats not what I'm asking about [obviously will have to redo it]
Took an inordinate amount of time, well over 8 hrs, and I know for sure I have made lithos this size and bigger in half the time. Usually just keep all my settings the same. the .03 for the bit I got from some calipers, is a 1/32 bit BN, obviously I can increase line spacing, what do you pros usually use for something this size ?
Litho gone wrong
- Xxray
Litho gone wrong
Doug
- Xxray
Re: Litho gone wrong
Can't edit anymore at all [nevermind, I see it]?
Thought I'd say, ironically, vcarves time estimate was like 90 minutes.
Doug
The estimate is meaningless until you've set the scale factor for the type of job being done, VCarve has no idea what the acceleration/deceleration settings and capabilities of the machine being used are. That becomes a bigger and bigger discrepancy the more three axis movement there is and there's a lot in a litho.
Here's where relying on percetage stepovers can deceive: 11% looks big; 0.003 inches is very small (your basic thickness of a yellow sticky note).
For 2900 goodly sized lines I can easily imagine 8 hours.
I am by no means a "pro" but it seems to me that a plunge rate of 30ipm is a bit slow for a machine capable of machining at a 300ipm feed rate. I'd double the Z axis feed rate if the machine is capable of it. I can't see your rapid clearance gap setting. I have found some improvement in machining time by setting it around 0.03. I've seen a number of examples of your litho work and most of it is quite good.
Ed
Ed
- Xxray
was pretty hazy last night, settings i used were when I was doing 3" square night lights so indeed, need to jack up line spacing
Doug
