Can you rotate a picture 90 degrees after import?
kristenanne77
Model of CNC Machine: ShapeOko 2
Post by kristenanne77 »
Is it possible to rotate a picture 90 degrees after importing it?
K
jfederer
Model of CNC Machine: CanCam D23M
Re: Can you rotate a picture 90 degrees after import?
Post by jfederer »
Yes. Just select the image, select the Rotate tool (3rd just under "Transform Objects") and either drag the handles or input the number of degrees desired. I do it frequently before extracting a vector set.
Joe Federer
www.federer.ca
Post by Rcnewcomb »
You can also press the 9 key twice with the object selected
kristenanne77
I see it in VCarve, but not in PhotoVCarve.
K
jfederer
Post by jfederer »
Ah! I missed that part! Sorry, I have no knowledge of that product. Hopefully someone else can answer this?
Joe Federer
www.federer.ca
With PhotoVCarve (the product) you cannot rotate the image once it's been imported.
With VCarve and Aspire you can rotate the image before using the Photo V-Carve toolpath within those products.
